134A Refer Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 10:16 PM   #1
Rewards Points: 85
134A refer question
So if R12 run around a 20-16 psi suction @ 15-20 degrees.
What should a 134A frige. run at?
I have a little prep. station/frig. that the compressor is running all the time and it will only get down to 50 degrees.
mikethe ductman is offline   Reply With Quote
Old 07-31-2010, 06:57 AM   #2
An old Tradesmen
Rewards Points: 6,470
14 to 18.
Old 07-31-2010, 01:29 PM   #3
if your suction pressure is that low and box temp at 50 what is discharge psi
jomama is offline   Reply With Quote
Old 07-31-2010, 03:56 PM   #4
An old Tradesmen
I don't think he said his vapor pressure is that low.
Old 07-31-2010, 06:45 PM   #5
Rewards Points: 85
I just took a look at the unit.
Box temp was around 50, suction pressure around 12-13 and cond. coil was dirty.
I cleaned the coil but little to no change on suction pressure.
Eased a littlr R134 in, got the suction pressure up to 18.
Looks like its not the first time being toped off, king valve looked a little chewed up.
I will follow up on it Monday to see if its working better.
Old 07-31-2010, 08:19 PM   #6
An old Tradesmen
Did you check the SH and SC?
At temp, the vapor line will be around 14 to 18.
On a warm box, it will be around 28 to 30.
Old 08-02-2010, 06:46 PM   #7
Rewards Points: 85
I went back by today.
The temp droped to 38 degrees.
The owner had replaced the t-stat some time ago.
He said it was set at 22 degrees
I don't know if the system will pull down that far, he keeps the unit between an oven and a pizza oven.
I will recheck the pressures next week.
Old 08-02-2010, 06:48 PM   #8
An old Tradesmen
LOL... pizza shop. Get the cheese and flower out of the condenser.
Old 08-03-2010, 01:05 AM   #9
he will need a jackhammer that stuff is like cement
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
