115v Mini-Split? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 07:47 AM   #1
Rewards Points: 14
115v Mini-Split?
I've got a 8x12 porch that has been enclosed & turned into a dining room. Open doorway to the kitchen, but I need to heat & cool it. It's at the far end of the house and through a finished concrete basement wall so extending the HVAC would probably mean upsizing all of the ducting in between...
A mini-split would seem to be the ticket, and a small one would do great. Right now I'm heating the room with an electric space heater, and I have no doubt that a small window ac unit would cool things nicely. The room gets north and east exposure only, so not a lot of sun load in the summer. The room has existing 115v outlets that aren't used for much of anything.
Are there any mini-split units that can run off a 115v circuit? The main panel is also at the far end of the house, and it would be a pain to run a new 230v circuit to feed the mini-split....
Any options?
AR-Trvlr is offline   Reply With Quote
Old 02-01-2013, 08:29 AM   #2
Rewards Points: 13,270
Never seen one, even is there was one it would need a dedicated 20 amp. circut so you would have to run another circut anyway.
Old 02-02-2013, 12:31 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Yes, there are 115V mini split units. Joe is correct, you would need a dedicated circuit. Here is one.... http://www.highseer.com/ductless-min...wyb009am9.html
They are typically no name or off brand units and parts and tech support are likely non-existent.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-07-2013, 03:43 AM   #4
Rewards Points: 1,016
Some of those newer models from various vendors with seer of 20's are 120v dedicated circuit.
____________
Vince
Mini split in basement? Mills314 HVAC 1 07-04-2011 10:36 AM
mini split BTU question... newbieowner HVAC 13 05-31-2011 10:57 PM
Mini split heat pump for us? Cedrus HVAC 5 03-08-2011 10:47 AM
mini split install bmancanfly HVAC 1 06-01-2009 04:57 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
