-   -   115v Mini-Split? (http://www.diychatroom.com/f17/115v-mini-split-170729/)
AR-Trvlr 02-01-2013 06:47 AM
115v Mini-Split?
I've got a 8x12 porch that has been enclosed & turned into a dining room. Open doorway to the kitchen, but I need to heat & cool it. It's at the far end of the house and through a finished concrete basement wall so extending the HVAC would probably mean upsizing all of the ducting in between...
A mini-split would seem to be the ticket, and a small one would do great. Right now I'm heating the room with an electric space heater, and I have no doubt that a small window ac unit would cool things nicely. The room gets north and east exposure only, so not a lot of sun load in the summer. The room has existing 115v outlets that aren't used for much of anything.
Are there any mini-split units that can run off a 115v circuit? The main panel is also at the far end of the house, and it would be a pain to run a new 230v circuit to feed the mini-split....
Any options?
joecaption 02-01-2013 07:29 AM
Never seen one, even is there was one it would need a dedicated 20 amp. circut so you would have to run another circut anyway.
hvactech126 02-02-2013 11:31 AM
Yes, there are 115V mini split units. Joe is correct, you would need a dedicated circuit. Here is one.... http://www.highseer.com/ductless-min...wyb009am9.html
They are typically no name or off brand units and parts and tech support are likely non-existent.
vsheetz 04-07-2013 02:43 AM
Some of those newer models from various vendors with seer of 20's are 120v dedicated circuit.
