Old 11-12-2012, 11:16 AM   #1
100 lbs propane tank - run furnace?
I have a 100 lbs propane tank, plan on using it as a back up to my geothermal when it gets -30 to -45 below. Usually only a week or two a year. Wondering if it will work, the tank is outside and will be runnning a 120,000 BTU forced air unit.
If not will a 250 lbs work. Dont need propane other than the gas stove and back up for just a week or two in the winter.
Really dont want to by a 250 if i dont have to.
Fisher is offline   Reply With Quote
Old 11-12-2012, 01:10 PM   #2
just depends on the heater, and how much LPG it uses
redman88 is offline   Reply With Quote
Old 11-12-2012, 01:30 PM   #3
Your propane company should be able to size the tank for you.
hvac benny is offline   Reply With Quote
Old 11-12-2012, 01:52 PM   #4
I doubt a vertical tank of either size will supply enough gas for a furnace that size in the indicated temperatures. You will probably need at least a 250 gallon horizontal tank to get enough liquid to change to a gas for that many BTU. Check with a local supplier, they should know.
Fairview is offline   Reply With Quote
Generator outlet and propane tank dougp23 Electrical 6 10-25-2011 02:32 AM
Propane Mower Conversion homerb Green Home Improvement 18 09-16-2010 01:01 PM
Heil nat/gas furnace coverstion to propane autospecialist HVAC 0 10-26-2009 09:46 AM
propane tank switch. waverly guy HVAC 13 09-14-2009 09:25 AM
Propane Tank sweaty Plumbing 2 06-08-2009 09:20 AM
