10 Yr Old Bryant Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 05:53 AM   #1
10 yr old Bryant Furnace
I have a problem with the Blower continuing to run to long after the burner cycles off. I have heard of limit switches that were not to costly to replace, but would like to know if this is the most likely problem, and where to locate them. This is an approx. 10 year old Bryant 93+ Forced Air Natural Gas Furnace. Thank You in Advance for any help !
Steve
b679995 is offline   Reply With Quote
Old 02-05-2013, 07:39 AM   #2
MarginallyQualified
Rewards Points: 2,464
too long after the burner cycles off.
1) Do you have a problem with the blower running until
the heat exchanger/plenum has cooled down to X degrees?
2) How long is "too long"?
but would like to know if this is the most likely problem...
Old 02-05-2013, 11:22 AM   #3
how
Rewards Points: 1,104
Does your circuit board not have some micro switches or gates that can be repositioned to change your fan "off" times?
Check your furnace manual.
how is offline   Reply With Quote
Tags
blower , bryant , limit switch
16-year old Bryant Plus-90 furnace phillip9 HVAC 5 03-05-2013 01:11 PM
Gas Furnace Replacement Questions mark2741 HVAC 31 01-17-2013 12:15 AM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 06:50 AM
Bryant Furnace pilot not lighting DGB HVAC 2 05-31-2009 11:47 AM
Bryant gas furnace internal water leak.... naexec HVAC 6 11-25-2008 12:40 AM
