1 Year Old Central Air Not Working Properly - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 03:16 PM   #31
He hasn't checked for a leak!!! He just added freon and said he thought it was just a loose cap (whatever that means). This is exactly why I'm so angry...because he hasn't checked for a leak!!! I was hoping he would open up some parts and check things out but none of this has been done. I appreciate all the info very much! I look very forward to the appointment to see what they say.
Gunner33 is offline   Reply With Quote
Old 06-08-2012, 03:21 PM   #32
BTW...It was 72 degrees last night and 71 degrees in the house. I turned on the air and it took and hour and 17 minutes to bring the house down 2 degrees to 69 degrees. I'm sure they'll consider this normal but I think it stinks!
Old 06-08-2012, 11:31 PM   #33
JackOfSomeTrade's Avatar
You wouldn't happen to be using our AC guy would you? Load more freon in and call it good and normal. Ya right! Think there's a little more going on here. Got an appointment ourselves this weekend to troubleshoot ours. Gonna pester the guy till he checks all the vents, pipes,etc. They've got to find something.
JackOfSomeTrade is offline   Reply With Quote
Old 06-09-2012, 11:41 AM   #34
Please let me know how it goes and what he finds! Good luck!
Old 06-10-2012, 02:16 AM   #35
Things are much better now. They actually found a leak in the high pressure line outside which had split in one of the loops of the coil. It was covered in dirt and that's what lead them to find it. Actually having oil in the freon helps out because when it leaks the dirt will adhere to it and make it easier to spot. This lead to the low freon condition which led to the indoor coils freezing up and cut down on the air flow. Hard to believe that one problem could snowball into many more. Problem solved. Oh and from what the AC guys says is that Goodman isn't a good brand of AC to have but nothing I can do about that now but good to know for future reference.
Old 06-10-2012, 10:00 AM   #36
If it's free...It's me
I have had a 3 ton packaged Goodman since 2005 and a split-system Goodman heat-pump since 2007. Both R-22 units. They have been working fine and they are fairly easy to work on and get parts for. Have a service performed at least yearly, preferably semi-annually if you have major season change. It may appear to cost a little more up front, but it beats being with out heat or AC for 3 days, and a service can prevent major repairs.
The BMW dealer is going to tell you that Chevy/Ford/Chrysler isn't a good car. But there are a lot pf people driving them. Hmmm.
Johnny'sHotDogs is offline   Reply With Quote
Old 06-27-2012, 03:10 PM   #37
Update:
Great news! After writing a letter to all parties involved...the hvac guy is here right now putting in a WHOLE BRAND NEW system! Should have put it in writing a long time ago!
Thank you to everyone who contributed to this thread!
Old 06-27-2012, 10:30 PM   #38
Congratulations!!!! Now enjoy the cool breeze as the summer is just getting started. Hopefully yours is a bit better than ours down here in AZ.
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 10:28 PM
Is my AC working correctly? Snoop101 HVAC 4 07-18-2010 10:34 PM
Flat roof resurface--EPDM, Torch Down, Cold Applied bitumen mgfuns Off Topic 3 07-07-2010 01:10 PM
Is My New Coil Working Properly...? ssporty21228 HVAC 1 08-23-2008 12:19 PM
sump pump working properly? Karen from Iowa Plumbing 7 06-18-2008 08:08 AM
