1 T-stat Works And 1 Doesnt, Single Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 08:15 PM   #1
1 t-stat works and 1 doesnt, single furnace
i have 1 furnace with 2 zones, 2 thermostats. the 1 upstairs works normally. the 1 downstairs will not turn on the heater. it will run the a/c and the fan. it worked fine 2 weeks ago. i tried replacing the thermostat, but still the same thing. any suggestions?
cazaam619 is offline   Reply With Quote
Old 11-05-2011, 08:42 PM   #2
An old Tradesmen
Rewards Points: 7,332
Check the wires in the zone panel.
problem with furnace will not turn on or works by itself tech2002 HVAC 3 12-29-2010 03:36 PM
my furnace only works when manually switched on khris HVAC 6 12-06-2010 07:54 PM
Problem with Carrier 58MXA furnace...everything works, furnace won't come on... Chipley HVAC 1 01-31-2010 05:04 PM
Furnace only works with door off CWinGA HVAC 3 12-05-2009 04:36 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 07:49 AM
