1-Stage Vs. 2-Stage Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2008, 09:54 PM   #1
1-Stage vs. 2-Stage Heat pump
I just bought the LUX TX9000TS thermostat to install on my Goodman AC/heatpump unit.
I am not familiar with the differences between 1-stage and 2-stage heat pumps.
If I installed the thermostat as a single stage unit instead of a 2-stage unit, would I have problems? If so, what would they be? Should I take this thing back and get another model?
ConanDan is offline   Reply With Quote
Old 08-02-2008, 07:46 AM   #2
sweaty
Rewards Points: 266
I am not an HVAC specialist, but I do know that all components should match each other. If you try to put together a "Frankenstein" system, you will lose the benefits of expensive equipment. It is best to bite the bullet and pay someone with competence and integrity to do it right.
sweaty is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 03:02 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
