1 Room, 2 Baseboard Thermostats - HVAC - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 04:23 PM   #1
1 room, 2 baseboard thermostats
In our Master bedroom there are two baseboard heaters. Each one is on a seperate circuit with its own thermostat.
I would like to have only one (programmable) thermostat in the room, but also don't want to have to completely re-wire everthing.
Does such a thing exist where a master, programmable thermostat can drive a seperate slave baseboard switch?
Thanks!
Jebross is offline   Reply With Quote
Old 04-17-2012, 05:20 PM   #2
An old Tradesmen
Rewards Points: 6,088
If both of the baseboards are fed from the same circuit, you can do it without fishing wires.
Old 04-18-2012, 09:45 AM   #3
Unfortunately they are on different breakers.
Old 04-18-2012, 04:43 PM   #4
An old Tradesmen
You'll need a relay/contactor set up then.
240 baseboard heaters dont work till room is warm? jeffo8 General DIY Discussions 5 12-13-2011 12:26 PM
Honeywell T6360B Dial Setting Room Thermostats 45ent Electrical 0 11-30-2011 03:24 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 07:31 PM
Electric Baseboard Heater Questions mark2741 HVAC 0 12-31-2010 01:08 PM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
