1.5 Ton Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 06:56 PM   #1
1.5 ton duct
i'm going to be installing a new duct system in the attic.900 sqft house 1.5 ton unit.total trunk line going to be about 20ft what size should my trunk line be? there will be about 6 6inch runs...thanks
buck545 is offline   Reply With Quote
Old 03-16-2013, 10:12 PM   #2
Rewards Points: 150
To properly size your truckline you would have to calculate the duct size for your equipment. Your best bet is first to buy a manual d book and use that to size your ducts. Its not that hard and people on this forum can guide you. I have done it a few times and its pretty easy. Pretty much once you understand what information you need then all you do is get the friction rate loss and then plug that into a ductulator to size your ducts correctly to your equipment.
kilosos2 is offline   Reply With Quote
Old 03-16-2013, 10:57 PM   #3
REP
I'd be just as interested in thew return duct system.Its not too hard to warn a 900 sq house unless you don't have a proper reurn for each room.
I'm thinking that you will need a 14x8 supply trunk and a 18x8 return trunk with a 20x8 buffalo boot.Going 20x8 on the return trunk to match up with the boot will also be fine.Its really hard to be too big on the return.
REP is offline   Reply With Quote
Old 03-17-2013, 05:28 AM   #4
An old Tradesmen
Rewards Points: 8,144
Better off with 16X8 for the supply. Allows for the air that those six 6" flex supplies won't carry.
Old 03-17-2013, 08:19 AM   #5
should I reduce the trunk line after the first couple of supplys?
Old 03-17-2013, 08:22 AM   #6
An old Tradesmen
Not if its less then 24 foot long.
Old 03-17-2013, 10:09 AM   #7
thanks
thanks guys
Old 03-19-2013, 06:16 PM   #8
flex
how many cfms does a 6 inch flex carry next to a 7inch flex duct,,,is there much of a difference?
Old 03-19-2013, 07:03 PM   #9
An old Tradesmen
6" 65cfm
7" 95cfm
Old 03-19-2013, 08:21 PM   #10
thanks again
so what size ceiling boot would I use for a 7in duct?, also for a 6inch duct
Old 03-19-2013, 08:34 PM   #11
An old Tradesmen
Are you looking at square or rectangular registers.
Rectangular, use 4X10. Square use 6" for 6", and 7 for 7.
Doing a dryer duct, the right way... nowwhatnapster HVAC 7 01-30-2013 07:52 PM
My Duct Sealing Project Cakemeister HVAC 6 06-13-2011 11:45 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
