Old 06-02-2012, 05:30 PM   #1
1/4 hp condenser motor??
Just bought a universal condenser motor and it wires up diff from my old one. It now has a xtra green/yellow (ground?) and I dont know to run it to?? It connected to a motor mount bolt on one end and the other end?? Help? Im in Dallas and my air cond being off isnt going to be nice soon. lol. Thanks
2nd question. The shaft doesnt fit the fan, can I file it??
1/4 hp condenser motor??-wp_000451-2-.jpg
andrewjetm is offline   Reply With Quote
Old 06-04-2012, 06:59 PM   #2
Andrew,
The ground wire is always supplied for aftermarket replacement motors. However, since your motor is mounted by the thru bolts directly to the steel top discharge fan guard it is no necessary to use the ground lead. Your motor will be properly grounded once you securely mount it.
It looks like you had to hacksaw the shaft to the correct length. This is not an issue. Go ahead and file the burr off the end of the shaft until your fan blade can slide past that point.
Globalguy
globalguy is offline   Reply With Quote
How to replace condensor fan motor? twags HVAC 41 09-13-2012 07:05 PM
Outside condenser fan motor stops tatums4 HVAC 21 10-12-2011 09:17 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 10:57 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 07:30 PM
