#1 |
1/3HP Blower To ?
I want to upgrade the blower in my Carrier unit from 1/3HP to 1/2HP or above. Is there a limit on the HP without making major electrical upgrades ?
The motor that is in it right now is : GE 3585 1/3 HP 115 Volts 1075 RPM 6.1 AMP |
#2 | |
It was a dark and stormy
1/3HP Blower To ?Quote:
The 1/2 hp motor will draw ~6.1x(0.5/0.3)= 10A so the wires that were carrying 6A will now have a temp. rise above ambient 3x higher than before so the life of the wire insulation may be shortened. You may not notice either of these effects. |
#3 |
An old Tradesmen
1/3HP Blower To ?
Guess you have poor air flow. And want to do this to push more air?
#4 |
1/3HP Blower To ?
Unless the existing motor is so overloaded by static pressure that it can't reach it's rated speed you probably won't see much difference in airflow just by changing the motor. The new motor will be the same rated speed as the old, so unless you also change the blower wheel you probably won't see much additional airflow.
| Display Modes | |
| Comfortmaker blower intermittent problem | jh44ny | HVAC | 12 | 07-31-2011 07:41 PM |
| Heat comes on but blower never does | aczer | HVAC | 12 | 02-13-2011 07:57 AM |
| Acceptable Blower Vibration | John_NH | HVAC | 15 | 11-21-2010 01:49 PM |
| Bryant Furnace Blower Running Constantly | GhostBuster | HVAC | 15 | 11-30-2008 10:08 PM |
| Blower control board | mlmaher | HVAC | 1 | 11-24-2007 02:39 PM |
