1 1/2 Inch Zone Valve - Can't Find - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 11:23 AM   #1
1 1/2 inch zone valve - can't find
I'm remodeling my basement and want to zone it. The existing heating system uses continuous 1 1/2 inch piping running around the perimeter of the house with venturis at each radiator. In the remodeled basement I'm using baseboard radiators with 3/4 inch plumbing.
At first I was just going to get a 1 1/2 inch zone valve for the upstairs heating and the run of the mill 3/4 inch for the basement, but the largest zone valve I can find is 1 1/4 and they are expensive. While I could use this with reducers, I didn't know if this would restrict the flow too much to the upstairs heating.
So, I got this bright idea that I would split the 1 1/2 supply line out of the boiler and use two 3/4" or 1 inch zone valves in parallel and combine back to 1 1/2 inch on the other side.
Would this work or am I out to lunch?
BOUTYM is offline   Reply With Quote
Old 10-28-2008, 08:35 AM   #2
An old Tradesmen
Rewards Points: 6,116
Venturis???
Is this a monoflo system.
If so, a 1" zone valve could be too small. And reduce water flow too much.
Easier way. Is to install a flow check on the existing loop, and use an IFC circ(Taco makes them) for the new basement zone.
May need to use a 2" flowcheck, depending on what circulator is on the mono loop.
Old 11-20-2008, 11:03 AM   #3
Originally Posted by beenthere View Post
Venturis???
It's an old monflo plumbed in 1 1/2 inch. I gave up the search anyway and ended up zoning it with IFC Grundfos circs.
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Zone Valve change motor jim99 HVAC 2 07-22-2007 07:37 AM
How to connect non-threaded 1/2 inch CPVC to a compression shut-off valve andy Plumbing 6 12-12-2006 10:02 PM
