York Rake / Harley Rake - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 09:55 PM   #1
york rake / harley rake
Does anyone have any experience with a york/ harely rake for prepping an area for seeding. The area in particular is on a hill with small rocks, debris, and various stumps/ roots (1"-2" diameter). I've heard the rack doesn't work properly on hills.
rcassidy is offline   Reply With Quote
Old 02-28-2009, 07:06 AM   #2
Harley / York Rake
Harley is going to give the seed a much quicker start by prepping the first 1-2" of soil. The Harley will also remove some of the rocks and sticks although not many of the 1". Harley also will do a better job "land planing" or moving soil from one area to another. Harley will double the price of your rental, but cut your prep time in half and give better results.
York rake will do an adequate job. It will pull out all the sticks and usually only 2" stone or above. It is alot harder to do any actual leveling but the hill may be hard to grade annyway.
When working on a hill always go up and down (perpendicular), and not side to side. With either attachment you may have to work from top to bottom and let gravity help you. It is never recomended to work on any slopes exceeding 20 degrees. A 4x4 hydrostatic tractor with a harley rake attachment may "feel" more comfortable to the occasional user (make sure it has a roll bar and seat belt and you use them). Tractor rollovers kill hundreds of people every year!
LandscapeRental is offline   Reply With Quote
York JCI Manufacture ApprovedComfort HVAC 21 03-12-2009 07:53 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
York gas heater control board replacement spyvan HVAC 5 12-29-2008 07:12 AM
York AC unit outside not turning on ssssg1 HVAC 1 07-25-2006 08:30 PM
new girl from new york 1crazygirl Introductions 4 06-02-2006 03:20 PM
