Yard Is Uneven And Bumpy - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-14-2014, 02:42 PM   #1
Rewards Points: 461
Yard is uneven and bumpy
Our back yard it really uneven and bumpy. Id like to get it nice and smooth and drain properly. Is there any other ways to go about this besides taking a rototiller and starting over?
cincinnati guy is offline   Reply With Quote
Old 04-14-2014, 02:56 PM   #2
Rewards Points: 6,652
Start calling landscaping companies or look in the local area Want advertisement paper, for people that own the equipment, that do this kind of work.
A single guy or gal on a Tractor doing the work in a couple of hours. Will be cheaper then what your labor is worth. They can even it out, add the proper additives depending on how your soil is.
Then just either have it Hydro-Seeded or Sod put down. Hydro-Seed will grow faster then just putting down seed and covering with straw. You do have to water it on a regular basis. Otherwise you will still have nothing but dirt for a yard.
Old 04-14-2014, 03:03 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I think it all depends on how big a yard you have.
Robpo is offline   Reply With Quote
Old 04-14-2014, 06:57 PM   #4
Rewards Points: 402
Are you talking about little bumps or rolling hills? If it's the usual little bumps that appear in the spring, you could have someone come out after a good hard rain and the ground is really saturated, and roll it to try and smooth it out.
taylorjm is offline   Reply With Quote
Uneven second coat on trim... asbury park Painting 17 01-21-2012 07:35 PM
Concrete form over uneven surface cvbrewer General DIY Discussions 6 08-21-2011 07:32 AM
Oil Based Primer - Bumpy Finish mvt2k7 Painting 5 08-18-2010 03:04 PM
Help, my house came with a yard! gregdonovan Landscaping & Lawn Care 1 11-09-2009 04:22 AM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
