Yard Slope - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-02-2016, 11:05 PM   #1
Rewards Points: 2
Yard slope
I am building a small parking pad next to my garage and patio. My lot is really flat, so I spent a ton of time making sure the ground is sloped away from everything, and towards the alley. Today my load of gravel was delivered... My question is, how much should I try and slope the gravel? Can I just level it?
Am I crazy to think that as long as the ground is sloped correctly, the rain and snow melt will drain through the gravel, and go to the alley?
RustyTrombone is offline   Reply With Quote
Old 09-03-2016, 10:12 AM   #2
Rewards Points: 2,384
Re: Yard slope
Do you have crushed gravel, or round gravel?
Crushed gravel will lock together and cause the voids between stones to be smaller, or non-existent, which may cause pooling.
Round gravel has much larger voids so water flows easily through them.
Hope this helps.
ED
de-nagorg is offline   Reply With Quote
Old 09-06-2016, 01:05 PM   #3
Rewards Points: 844
Re: Yard slope
I see it as either the gravel is going to compact and the water drain with the slope of the gravel or it won't compact and the water will flow through and flow with the slope of the surface underneath.
"Gravel" is a pretty vague term.
stick\shift is offline   Reply With Quote
Old 09-06-2016, 07:33 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,958
Re: Yard slope
Unless I'm missing something, you are blending concepts. Slope will cause the water/snow melt to flow in a particular direction - in your case, towards the alley. Gravel will allow it to percolate down into the soil. Since you mention "snow melt", you should be more concerned about slope since when the ground is frozen, liquid will not be percolating anywhere.
Something else to consider depending on your location: Some municipalities have bylaws that require surface water to be handled within the bounds of the property (i.e. not directed to a neighbour or to municipal land except as designed, such as a ditch, drain, etc.). Depending on your situation, climate, etc. you might be leaving yourself open to a complaint.
lenaitch is offline   Reply With Quote
Old 09-06-2016, 08:06 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Re: Yard slope
Ayuh,..... Carry the pitch necessary to drain the area,....
Both the sub-grade, 'n the finish grade,....
If the sub-grade is pitched, 'n ya add an even layer of toppin', Both will be pitched,....
If any water gets under the toppin', it'll still drain off,...
Win- Win,....
fixing up ugly side yard with no sun bobble Landscaping & Lawn Care 0 04-27-2016 06:35 PM
Retaining wall vs grading slope pros / cons advice please afrig Landscaping & Lawn Care 11 03-09-2016 03:38 PM
How should i slope this section of gutter? tireshark Roofing/Siding 8 12-21-2015 11:47 AM
Slope along edge of kitchen (vinyl over hardwood) TOTALN00B Flooring 1 04-23-2011 03:34 PM
Closet Light issue, Need Help mount on slope bfan781 Electrical 13 04-12-2010 08:31 PM
