Is This Wrong? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 07:50 PM   #1
Is this wrong?
We are currently building a new home and i just had a home inspector in to look over all of the house, top to bottom, inside and out. He pointed out a major problem with the grading in the one outside corner of the home. Please see pictures.
He pointed out that they graded the land/water directly to the house and sooner or later water will get into the basement. I asked what the fix was and he suggested a retaining wall. I do agree with him but wanted some second opinions on this.
jerrydanish is offline   Reply With Quote
Old 08-19-2011, 08:12 PM   #2
Learning by Doing
Leah Frances's Avatar
He's right. It is wrong.
Water will pool there (even if it is only during a downpour) and find it's way into your basement. You need to talk to someone who can design a system for your house to manage all the surface water away from your house.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-19-2011, 08:32 PM   #3
Rewards Points: 558
Or raise the air conditioning unit and have that area properly graded. All grading should slop away from the house.
epson is offline   Reply With Quote
Old 08-19-2011, 08:50 PM   #4
check to see if you have a french drain?there should be a pipe exit at daylight?the walls should have been sealed and a drain installed.
if not a wall and slab w/drains or good slope will fix you up.
Marbledust is offline   Reply With Quote
Old 08-19-2011, 09:02 PM   #5
here's a picture of the wall. Sealed, not really and I do not know if they stuck in a french drain.
Old 08-19-2011, 09:35 PM   #6
Rewards Points: 558
I donít see any weeping tile either
Old 08-20-2011, 03:55 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 300
The builder should come back and fix it. That is just wrong.
Old 08-20-2011, 06:27 AM   #8
thanks for everyone's input. The other thing I caught last night reading the builders hand book. It states that "the home comes with a one year dry basement guarantee but is void if the grades are not kept in good original condition".. ok so I go to the grading section of the hand book and states "all grading will be accomplished to cause the water to flow away from you home".
So they installed something that voids their own warranty.... I'm going to talk to them today about this. I'll let everyone know how it turns out.
The Following 3 Users Say Thank You to jerrydanish For This Useful Post:
concretemasonry (08-20-2011), fuzzmanks (08-22-2011), Leah Frances (08-20-2011)
Old 08-20-2011, 05:30 PM   #9
TimAllen37's Avatar
i agree, someone should come back and fix that. that is horrible!
TimAllen37 is offline   Reply With Quote
Old 08-20-2011, 05:46 PM   #10
the Musigician
DangerMouse's Avatar
Wow.....
I can't wait for the next post.
DM
Old 08-20-2011, 05:47 PM   #11
also, where does the gutter next to the driveway drain to ? Is it buried into the ground?
rntonp is offline   Reply With Quote
Old 08-20-2011, 05:48 PM   #12
Rewards Points: 150
I would also bury a drain for that downspout by the step, take it out about 20' at a 45* angle.
josall is offline   Reply With Quote
Old 08-21-2011, 04:21 AM   #13
chrisn's Avatar
Rewards Points: 300
Good luck with that. I would have a good lawyer friend on call
Old 08-21-2011, 09:07 AM   #14
Civil Engineer
Rewards Points: 4,686
You said you were building a new house. I assume you have plans for the house, or is this a spec house that you purchased? If you have plans, check the grading on the plans carefully to see what they show. As noted, this grading plan is not standard practice. You should also check your plans to see if a perimeter drain is included, most new houses I have seen have them.
Old 08-22-2011, 06:25 AM   #15
Below is the only blue print that show the grading.. I sent the home inspection report to the sales rep yesterday and she sent it right to the regional manager. I did talk to the sales rep and she did say that there is a French drain around the whole back of the house and that the possibility of water damage in that area is slim to none because of the 10inch poured walls. I have a friend that engineers walls, he said the same thing. I am meeting with the site manager today, so let see what he says.
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 13 08-01-2016 05:33 AM
2 handle shower wrong direction Lisa C Plumbing 7 07-24-2011 09:28 AM
Water Heater, wrong connections? HAMP Plumbing 7 02-09-2011 10:57 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
