Wood Preservative On Cut Timbers? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 01:00 PM   #1
Wood preservative on cut timbers?
I am building wooden steps using 6" x 6" PT timbers from Lowes and following the procedure shown in an online video from This Old House - http://www.thisoldhouse.com/toh/vide...630959,00.html I will start wih two 4-foot "sleepers" underground, then will create 4-foot long treads by cutting 8-foot timbers in half. In that video, a wood preservative is applied with paint brush to the cut ends of each piece. While looking for such preservative at Lowes, I was told that the pressure treatment extends throughout the entire timber and that a wood preservative is not needed. Can anyone provide me with more information on this topic? Do I need to apply a preservative to the cut ends? If so, what type or name brand of preservative is recommended?
Many thanks for any help you can provide!
RetiredJim
RetiredJim is offline   Reply With Quote
Old 06-26-2013, 08:05 PM   #2
Rewards Points: 13,694
The last thing you want be doing is taking advise from a box store.
Not likely anyone's going to be watching that video.
Never once head of cutting timbers in half to make a tread.
Just use 5/4 decking boards or 2X 6's.
No way does the pressure treating go all the way to the center of a 6 X 6.
No clue what your considering to be "sleepers" under ground.
RetiredJim (06-26-2013)
Old 06-26-2013, 08:15 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,754
Joe's right... PT does not permeat the whole board/timber.EDIT: Not even close
Considering the project, just timber steps, I'd use any resonably priced shelf, preserative on your cutends. It's just a reasonably priced good thing to do.... especially on end grain.
Joe .... I'm not sure what else you were refering to???
Best
Peter
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 06-26-2013, 09:28 PM   #4
Thanks to Joe and MTN for your comments, especially with regard to pressure treated lumber. If I use the 6" x 6" timbers as shown in that video, I will definitely treat the end grains with a wood preservative.
I am building steps into a hillside with rise:run ratio of 1:3. After checking out the very few methods found in my online search, I preferred the use of timbers (as shown in the aforementioned video) to create steps that are completely closed.
Comments and critiques of this technique would be welcome and appreciated.In the video, 6" by 6" timbers were cut and used as the treads, thus making the rise 5.5 inches. Two side-by-side timber "treads" were used for each step or "run", thus each step had a rise of 5.5 inches and a run of 11 inches. (I was planning to use three timbers for each step to achieve a run of 16.5 inches, which is the recommended distance for a run of 5.5 inches.) The "sleepers" are the buried timbers that run perpendicular to the treads and upon which the timber treads sit. The first layer of sleepers is stabilized with two 4-foot sections of iron rebar through holes in each sleeper and hammered all the way into the ground beneath. After the first step is created, a new pair of sleepers sits on top of the original pair, behind the treads, and extends about 16 inches farther out. The timbers are to be attached with 10-inch TimberTite screws, special fasteners for landscape walls, etc.
Last edited by RetiredJim; 06-27-2013 at 12:24 AM. Reason: Clarity of writing, and additional thanks.
Tags
pressure treated wood , wood preservative
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
