Wood Fence Gate Width - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 05:56 PM   #1
Rewards Points: 324
Hello,
We are in process of installing 6ft (treated wood) privacy fence. Initially I wanted 4 or 5ft wide gate to allow easy access for commercial mowers. Is it advisable to have double wide 3ft gates instead since 4 or 5ft are too heavy?
Thank you!
sbkim is offline   Reply With Quote
Old 10-22-2012, 06:00 PM   #2
Rewards Points: 13,274
Simple ansewer is yes. One that big without taking speceal pecautions would be sure to sag.
user1007 (10-22-2012)
Old 10-22-2012, 06:17 PM   #3
Rewards Points: 324
Got it thank you. I apologize for stupid question but I presume you can request one of the doors which will be used the least to be "anchored" or have some stop? Just curious what term to use to describe this to my installers?
Old 10-22-2012, 06:41 PM   #4
Too Short? Cut it Again!
And structure on the hinge side, if a swinging gate, would have to be robust. You would have to brace/turnbuckle it and/or put a wheel or something under the non-hinge corner. If you had room for a sliding gate, that might be doable but with a hefty track for it to ride along.
The fact of the matter is you will not need the full width of a large gate all the time anyhow.
Easiest way to anchor the side of the double gate that does not swing all the time is with a rod that anchors down through a plate and then into a hole in the sidewalk. This is fairly standard gate hardware so your contractor should know what you want.
Old 10-22-2012, 08:06 PM   #5
It's called a drop rod.
http://www.bing.com/images/search?q=...4234E&first=82
Old 10-22-2012, 11:30 PM   #6
Rewards Points: 324
You guys are great! Thank you so much. Will request double wide 3ft gates with drop rod
Old 10-28-2012, 08:40 PM   #7
Gate
Very informative post! I think a gate can be very helpful for keeping wildlife out of gardens.
Jess_718 is offline   Reply With Quote
Need with putting on a new gate and fence GanJa Building & Construction 15 08-27-2012 08:12 AM
Vinyl or Wood Fence? hkolln Landscaping & Lawn Care 3 08-22-2012 08:40 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 07:03 PM
Gate for wooden privacy fence RookVega Landscaping & Lawn Care 2 11-09-2008 10:56 AM
