Wiregrass And Crabgrass - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 12:35 PM   #1
Wiregrass and Crabgrass
I live on a lake and my back yard lawn gets infested near the water by wore grass. I spray Bayer weed killer for grass and it barely makes a dent - use it too much and it kills the grass.
The annual infestation of Crabgrass is here even though I use the barrier Scotts Crabgrass treatment every march.
Fall will be here soon and I need to get some heavy crabgrass areas killed off and get some grass in there - anyone have ideas for all this stuff?
I tried to grow a nice grass lawn to starve off this stuff but it comes back every year. Maybe it's time to say "it's green" and leave it be like others do
JackVa1 is offline   Reply With Quote
Old 08-05-2009, 01:33 PM   #2
Rewards Points: 874
In my opinion, you should not be using weed killer chemicals near the water. Eventually, the lake will become polluted, and fish, etc will die off.
I would recommend covering the bad grass with an opaque (doesn't let the light through) tarp for a couple of weeks, so that the grass dies.
Then, turn it under, and plant the new grass in the new soil.
Sod would be your best bet, since it doesn't take time to grow in.
Just my opinion.
I hate lawn and garden chemicals.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 08-06-2009, 06:56 PM   #3
Don't know it all, yet!
Where to start?
Do I understand that you using the Bayer weed killer to control the wiregrass? Is this product not for "broadleaf" weeds that are present in your grass (lawn)?
I do suppose that you can overdose enough to do that.
Crabgrass is not an "annual" infestation.
Are you aware that pre-emergents have about a 12 week control window? I applied Treflan in February. It stopped working two months ago. So I re-applied a couple of weeks ago when I started having to pull weeds out by the 5 gallon bucket full.
Well, you could use some MSMA crabgrass killer. Or you could use some glyphosate- it is deactivated by bacteria in the soil (and water) and should be safe near your lake. Just apply properly.
READ ALL LABELS for indicated uses near waterways.
One plan-
Kill all the weeds by whatever method you are comfortable with. Re-seed the area. With fall coming on you are at a good time. Irrigate properly. Next year, late winter/ early spring apply the appropriate pre-emergent and fertlize properly.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-07-2009, 10:36 AM   #4
Lightbulb
One plan-
Kill all the weeds by whatever method you are comfortable with. Re-seed the area. With fall coming on you are at a good time. Irrigate properly. Next year, late winter/ early spring apply the appropriate pre-emergent and fertlize properly. (Quote from Downunder)
FW
I did something kinda like these suggestions about ten years ago and it worked out well. Covered a section of the yard for about two months with black plastic. Removed it and loosened the top layer and raked/picked out anything that looked like it might possibly grow or harbor a viable root or seed. Then seeded with my grass and followed up later with whatever maintenance products--seems like it was 3 or 4 months later that I started that. Back then my yard was teeteeteeny and I didn't want to risk harming my flower and veggie gardens.
There was an area by a fence in that same yard that I wanted to make a shade garden. But it just wanted to be wild because the neighbor's yard was overgrown and wild. It wasn't worth the time or the cost to battle that and in the end I planted a vine that looks like a wild clematis that grows in these parts by the river in the middle of the mess to make it appear that the patch was intentional to showcase the native plant.
Good luck with however you decide to tackle it.
Last edited by Tess; 08-07-2009 at 10:38 AM. Reason: To try to get the two quotes in right =p
Tess is offline   Reply With Quote
