Winter Over Plants - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 10:42 AM   #1
Rewards Points: 150
Winter over plants
Hey green thumb's
Is there a book explaining what plants can be winterovered in my basement and how? I live in Michigan with a Michigan basement.
The frost very little has not had any affect on the plants yet.
Deckn hand
deck hand is offline   Reply With Quote
Old 10-28-2008, 10:57 AM   #2
the Musigician
DangerMouse's Avatar
depends on what type of plant and the conditions in that short basement.
DM
Old 10-28-2008, 03:52 PM   #3
Rewards Points: 150
DM
Wish I knew ? I will get back with you when I ask Her Majesty the gardener
Thanks deck hand
Old 10-28-2008, 04:56 PM   #4
overwintering
I'd love to know, too. I have gaura, geranium and a tropical Mandevilla I want to keep in my Chicago basement. Not sure if I need extra light or what else I need to do.
Allison1888 is offline   Reply With Quote
Old 10-28-2008, 08:15 PM   #5
Don't know it all, yet!
Generally, any herbaceous perennial that is not cold hardy should overwinter fine in a basement once it has gone dormant. An example in the Atlanta area would be Pennisetum (Fountain grass). It will die if left in the ground but dug up and left overwinter in a garage is fine. I cut the foliage back to about six inches, just enough for a "handle", and just put them over in a corner somewhere until spring.
If it is not herbaceous, that is, does not loose its leaves and go dormant, then it will need to be brought into a lighted room. Think of a houseplant.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 10-28-2008, 09:05 PM   #6
Rewards Points: 150
winter over plants
Ok I think I'm ok, I made a long two teer bench, set all the planters in a row. ( 12 of them all potted )
added a small amount of water. and a floresent light on a timer .
the basement is generaly about 50 degrees through the winter, unless it gets below zero for an extended time. .Then I will open the vent from the furnace this will control the temp. If the leaf's fall off I will cut them back to three inches.
I will keeep a log as to what plants make it, what won't. Trial and error ?
Wish me luck !
Deck hand
Old 11-10-2008, 10:26 AM   #7
the Musigician
Originally Posted by carterdan View Post
I hate winter, wish summer lasted all year.
i know what you mean, we all dislike things.... like people who break the simple rules here....
DM
I can't paint my whole exterior before winter, and I have some exposed wood skiposwald Painting 1 10-15-2008 01:06 AM
Caring for hostas and other plants that were neglected this past winter curls00 Landscaping & Lawn Care 8 04-23-2008 04:26 PM
Hello from Buffalo where winter is WINTER tvlfleming Introductions 6 02-06-2007 08:00 PM
Winterizing stawberry plants dwayne Landscaping & Lawn Care 6 10-22-2006 11:48 AM
Summer / winter differences... buggie Building & Construction 3 12-24-2005 10:34 AM
