Window Wells...what To Do? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 05:02 PM   #1
analogmusicman's Avatar
Rewards Points: 560
window wells...what to do?
ok guys, look at the pic...it's 1 of 2 window-wells in the front of the house. what I'd like to do is put something around it like maybe a real short wall. this would keep me from having to dig out a bunch of dirt to level everything. so any ideas? I'm open to suggestions. and oh yes,those watering "heads" will be removed.
tnx,
analogmusicman is offline   Reply With Quote
Old 03-06-2012, 05:18 PM   #2
You may be able to bend a 6" wide plexiglas strip around those radii without having to heat it first. Don't forget to caulk.
Old 03-06-2012, 05:38 PM   #3
bbo
you could also buy another window well and cut it to proper height and attach to current window well.
I would probably just dig around this one and get one of the proper height ( they are stacking ones made too)
bbo is offline   Reply With Quote
Old 03-06-2012, 05:55 PM   #4
Rewards Points: 560
one consideration,and why I thought of a low wall, is that the "window well cover" sticks out a bit from the window well.
tnx,
Old 03-07-2012, 09:23 PM   #5
Rewards Points: 560
if I decide to put a short wall around the "window well" (probably using some sort of heavy paver), would I have to have a "footing" underneath and if so, how thick should the concrete be? (I recall that someone talked about the soil around window-wells not being compacted much)
tnx.
Old 03-11-2012, 07:26 AM   #6
Happy to help
Lighting Retro's Avatar
Wow, that looks like a real pain the rear. I wouldn't fudge on that one. Anything you do to build up around it will make it infinitely more difficult to access or repair in the future. Like others have mentioned, I would look to stack on the existing, as it is just too low. That will solve your issue and would eliminate the need for a temporary solution.
Lighting Retro is offline   Reply With Quote
Old 08-11-2012, 11:43 AM   #7
I have a low spot in my side yard and when we get heavy rain it pools and runs back on to the patio and then into the window well and basement.I have two estimates and one says to put in a french drain and pipe to run along side of the house out to the street.the other wants to put a swale and alot of grading which they want $4000.00+ for the work. the other wants $2750.00 for the french drain approach. I would likdback on french drains and if thats the way to go. I don't want to spend that kind of money and continue to have problems. Thanks for your thoughts. Does this sound reasonable for the work being done?
matooz is offline   Reply With Quote
Old 08-11-2012, 12:08 PM   #8
Rewards Points: 560
I built a short wall around the "well". it'll have stone around it too. I'll post a pic when it's finished.
tnx,
Old 08-11-2012, 01:42 PM   #9
window well&water problem
if I add dirt to the low area, then it becomes higher than my patio and will run back faster to the window well thus filling them up. Thats why I asked for feedback about the french well and does the cost of $2700.50 sound reasonable?
Old 08-11-2012, 02:55 PM   #10
Too Short? Cut it Again!
Is a french drain legal where you are?
Old 08-11-2012, 06:04 PM   #11
french drains and window well waterproblems
yes french drains are legal but I'm looking for a long term solution and if this is it thats fine. I just don't want to spend $2750.00 and continue to have problems. I can't dig out around the window wells as concrete was laid around them when we put the patio in.
Home Extension Over Window Wells instantbradley Building & Construction 7 02-10-2012 08:19 PM
Window Wells paruggeri Landscaping & Lawn Care 0 06-18-2011 07:02 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
