Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-13-2008, 03:29 PM   #1
window well filling with water
I have 3 window wells. if it rains hard, it will fill up with water. we just had about 5 inch rain storm last night, and you could see the water level in the well was halfway up the window, and seeping in through the window, into the basement. also, the well is not bolted to the foundation. is this an easy job to fix? what all is involved?
icu2mamma is offline   Reply With Quote
Old 06-13-2008, 04:07 PM   #2
47_47's Avatar
How is the grade of the ground by the window well? It should be sloping away from the house.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 06-13-2008, 07:05 PM   #3
Don't know it all, yet!
In addition to 47's excellent advice, how is the water getting in the wells in the first place? Are they simply catching the water like a giant rain guage along with what falls down the wall? Is there any kind of drain in each or, if not, could one be installed? Something like a french drain or a dry well or a catch basin type with an outlet away from the house.
downunder is offline   Reply With Quote
Old 06-17-2008, 03:27 PM   #4
Mechanical Engineer
comp1911's Avatar
Good advice so far. The simple solution I see is window well covers to keep the rain out.
Bottom line, the wells fill up because the water is going in to them faster then it drains out. The well should have a drain tied to the drain tile or have media (rock) that the water can drain through to get to the tile. This is assuming there is drain tile around the house.
My well has both but its a bigger CMU block unit.
comp1911 is offline   Reply With Quote
Old 06-17-2008, 04:01 PM   #5
Why do you have about 1 feet of corrugated piping sticking above the stone? I assume the piping is perforated, but still, why 1 feet?
handy man88 is offline   Reply With Quote
Old 06-17-2008, 04:01 PM   #6
Buy and install window well covers.
Old 06-17-2008, 05:38 PM   #7
Mechanical Engineer
comp1911's Avatar
Old picture of it roughed in. I just hadn't got in there and cut it flush and put the drain cover on it.
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
