Why Use This Type Herbicide?? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 12:44 PM   #1
Why use this type herbicide??
By Mistake--My wife bought an Ortho Herbicide that is desighned to be applied AFTER MOWING!
To me, that doesn't make sense. After you mow the lawn, the weeds are gone. I guess this is used as a broadcast spray and not spot sprayed.
Giles is offline   Reply With Quote
Old 03-11-2011, 12:46 PM   #2
Learning by Doing
Leah Frances's Avatar
My understanding (correct me if I'm wrong - PLEASE) is that when the mower makes cuts in the broad-leaf or other weeds it exposes enough of the plants cells to absorb the herbicide. I was told (I know not a good source) that it allows you to use less herbicide.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-11-2011, 01:20 PM   #3
After the weed is cut ----how do you know where it is??
I have always got good results fron "weed-be-gone" and she thought that was what she was buying.
Guess I'll return it for the proper herbacide.
Old 03-11-2011, 02:56 PM   #4
Having the herbicide make good leaf contact is key to weeds being controlled. So you're right "after" mowing doesn't make sense. The more leaves the herbicide makes contact with the more thorough/quicker kill you get. Technically you don't have to mix/apply the weed killer as heavy or hot either.
Gerald Allen is offline   Reply With Quote
Circuit breaker Type Q vs QP orange Electrical 6 12-15-2010 03:35 PM
screw type bulbs. mpj111 Electrical 5 01-27-2009 03:27 PM
Type WL Copper Pipe bathroom slave Plumbing 1 01-26-2009 12:30 AM
Need help with Type T and TL fuses? Fotoguy Electrical 6 03-04-2008 01:08 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
