Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-10-2012, 11:57 AM   #1
Why do commercial landscapers mound the mulch so high?
All commercial buildings have the mulch like a foot high. What's the point?
smokey847 is offline   Reply With Quote
Old 02-10-2012, 12:07 PM   #2
Ironlight's Avatar
Weed control and moisture retention. The more mulch, the less frequent the maintenance rounds/visits.
Ironlight is offline   Reply With Quote
Old 02-10-2012, 12:53 PM   #3
It's poor landscaping regardless of the reason, unless it's done in areas with little vegetation. If, however, it is done around shrubs, perennials, etc. the roots can retain so much water that the excess mulch is basically suffocating the roots. Old mulch should be removed before new is put down, but that rarely happens.
cibula11 is offline   Reply With Quote
Old 02-10-2012, 01:52 PM   #4
sdsester's Avatar
I agree. Good mulch does not have to be 48" thick. Money in it though. I guess some people think it is "a look!?"
It actually can be a hazard. Ever seen wood shavings internally combust? I have. 48" will not do it but will give off steam on a cool morning. I used to grab the horrid power company tree trimmers and ask them to dump a truck full in my yard. If I didn't get to moving it around, it would steam and smoke and potentially catch on fire.
Mulch, at least the layer near the soil, steals nitrogen from the soil. You have to compensate with a simple high nitrogen only fertilizer depending on how much mulch you add for this reason, at least with simple bedding plants.
One of the mulch materials I like the best? Cleaned and washed tire fragments. Available in color. You do not have to lay them on thick. They are easy to rake. They are recycled and they look nice and stay in place since they are heavier than wood chips.
You serve no purpose tilling them into the soil though.
sdsester is offline   Reply With Quote
Old 02-10-2012, 11:43 PM   #5
Many reasons:
1. These landscape companies hire people who know nothing about landscaping or plants.
2. People who hire these services feel like they're getting a good deal b/c more is better.
3. Having the mulch pile high causes the roots to grow towards the top rather than dig in deep into the soil, which is bad during storms.
handy man88 is offline   Reply With Quote
Old 02-14-2012, 10:07 AM   #6
There is no point. The people performing the work have no idea what they are doing. This errant "mulch volcano" approach is not only degrading to the landscape aesthetics but in fact is detrimental to the trees. Mulch volcanos are a good indication that the wrong landscaper is under contract.
Wrooster
wrooster is offline   Reply With Quote
Old 02-14-2012, 10:22 AM   #7
http://ohioline.osu.edu/hyg-fact/1000/1083.html
Old 02-14-2012, 07:55 PM   #8
GardenConcepts's Avatar
Not ALL landscapers practice volcano mulching. It is definitively bad for the plants and a waste of money.
There are other misguided practices that so-called landscape professionals employ, such as pruning tree branches flush to the trunk, painting pruning cuts with asphalt sealer, planting Bradford Pears, installing plants too close to one another and/or too close to a building... I could go on and on.
Chris
GardenConcepts is offline   Reply With Quote
Old 02-15-2012, 08:09 AM   #9
Non-Crafty Newbie
Meenie50's Avatar
Hi Chris,
What's wrong with Bradford Pears? They're beautiful in the Spring. When I lived in Virginia and we had a hurricane, the poor things were destroyed - the wind just twisted them and they were either terribly deformed or broken - so that's a disadvantage. Most people replanted with some type of newer version of the bradford pear (I forget the name).
Meenie50 is offline   Reply With Quote
Old 02-15-2012, 08:37 AM   #10
Bradford Pears self-destruct just as they are maturing- especially in areas with snow. Many landscapers still plant this cultivar of Callery Pear, well aware of the problems. Other cultivars of Callery Pear that are less prone to breaking apart are 'Aristocrat', 'Cleveland Select', and 'Capital'. While these cultivars are considered sterile, they are quite capable of cross-pollinating with different cultivars and can and do become invasive in disturbed areas such as roadsides and fields.
Chris
Old 02-15-2012, 09:15 AM   #11
Non-Crafty Newbie
Meenie50's Avatar
Thanks Chris, that's good info to know!!
Old 02-21-2012, 04:58 PM   #12
I learned in landscape design school that it's bad to do this and if it is done it's purely for appearance sake. It may look good, but it's bad for your plants.
heatherb88 is offline   Reply With Quote
Old 02-21-2012, 05:01 PM   #13
But, it doesn't look good. This is why I can't understand why it is done.
Wrooster
Old 02-21-2012, 06:07 PM   #14
Non-Crafty Newbie
Meenie50's Avatar
I don't think it looks good either and, if it's done by a "professional", it just makes them look like a nincompoop!!
Wrooster
2 Pipe Fan Coil AC vertical Cab - 1/10HP Blower Motor High Speed Problem Tyndale HVAC 5 07-10-2011 01:50 PM
Electrical Problem w/ New AC Blower Motors - High Speed shuts off after 15 Min? Tyndale Electrical 6 07-10-2011 04:58 AM
Irrigation Mound???? rollinastang Plumbing 2 05-19-2011 01:24 PM
Rubber mulch Vs. Kids Carpet mulch for backyard play system whataboutj Landscaping & Lawn Care 1 04-26-2010 11:22 AM
Playground mulch in a garden bed? pjm Landscaping & Lawn Care 5 05-20-2009 04:28 PM
