Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-25-2006, 09:52 AM   #1
They're all fixer-uppers
J187's Avatar
Whoa, how much water can my irrigation system use???
Ok, I havne't had a chance to investigate my meter yet, but I just opened my waterbill at work. Its really the first water bill I've received since buying the house in April except for one bill for $40 while we were working on the house, not living there. The bill is $400, $240 of which is for my irrigation system. The irrigation is on a sep meter, so no sewer tax, but the use of 44 units - ea unit being 738 gallons, means I used 33,000 gallons in 3 months?? Is that possible?
I have 25 sprinkler heads over 24K sq ft of land. I don't think I used the system more than like 15 times only running it for around 1 hour total for all heads.
J187 is offline   Reply With Quote
Old 10-28-2006, 08:52 AM   #2
I would be checking the meter VERY fast. It could be a leak or a valve that is not shutting off completely when the system is supposed to be off.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-30-2006, 09:40 PM   #3
remodeling pro
That does sound pretty high. Even if all 25 heads are turf rotors or impact heads flowing at 4 gpm, that is 100 gpm total times 60 min, for a flow of 6000 gph times 15 hours equals 9000 gallons. If you are pretty sure that you are not underestimating the run time, I'd be looking for a leak. Since most irrigation piping is buried relatively shallow, a very soggy area should be easy to find.
troubleseeker is offline   Reply With Quote
Old 10-31-2006, 02:30 PM   #4
J187's Avatar
Thanks guys, I do believe I found the culprit. I have a hose bib around the side of my house no one ever goes to. A couple months ago, a buddy was helping me pour concrete for a lamp post. I beleive he left the bib on because I found the hose with the head exploded off of it. Now, I remember finding the bib on and turning it off, but didn't see the hose whereas the hose is around the side of the house from the bib. Now, putting two and two together, I am guessing the hose head blew off and ran for several days until I found the bib on. It rained for the majority of that month here, I never would have notice. Grrrr. Thanks. At least I can feel comfortable about using the sprinkler.
Old 10-06-2008, 12:19 PM   #5
It is very likely that your sprinkler did use that much water. Check your meter while your system is off to make sure there are no leaks.
lambkin1 is offline   Reply With Quote
Old 10-06-2008, 12:21 PM   #6
Yes your sprinkler system probably did use that much water.
Old 10-06-2008, 03:06 PM   #7
Been there done that. Had a water pipe break on my property and used 100,000 gallons. I found the leak and called the city. They forgave the bill which was a nice touch.
I have a meter on my irrigation system so that I can see if there is a leak.
I also have a whole house solenoid shutoff so that if there is no one home the computer shuts off the water, unless the sprinkler needs some water then the computer turns on the water till the irrigation is done.
The setup is the same at my vacation home. I don't want the pump running for months if I am not there. When it is time to irrigate the computer turns the pump on and then opens the water solenoid and it irrigates and then everything shuts down.
On my hose bibs I have have the same setup so that no water will go out unless the valves have been opened. The computer shuts down the water after 30 minutes and if there is need for more water then they have to be opened again.
Since I do all the programming I can adjust all the parameters to my life as needed but for years it has been running without me changing anything.
It keeps my water bill predictable and there are no surprises.
Marvin Gardens is offline   Reply With Quote
Old 10-27-2008, 09:28 PM   #8
just look on your meter and see how many gallons you use in a 10 minute period. If you used 120 gallons in 10 minutes you would use 720 gals per hour. (120 x 6 = 720) If it takes 3 hours to water then you used 2160 gallons 720 x 3 = 2160. 2160 x 6 waterings per month would = 12,960 gals per month. Each of your zones may vary a little as far as use is concerned but it will not vary that much. Systems are designed to put out the same amount of water that is coming in. Hence the need for "zones" in an irrigation system.
mhgcsuper is offline   Reply With Quote
Old 10-28-2008, 02:12 PM   #9
J187's Avatar
Wow, talk about reviving a dead thread. This was baby had its two year birthday this month. Anyway, you reminded me that I forgot to reply to this back then. Turns out it was a mistaken estimation which had been based on the previous month when the homeowner had a valve break and the water had leaked for like a day and a half.
Old 10-30-2008, 09:09 AM   #10
Here's my situation. I have 9 zones with a total of ~40 heads. 35 are rotors and 5 are spray heads. I have my system set to water for 4.5 hours 3 days a week. If they were to water each time it is set to go (36 times in 3 months) how many gallons would you guess I would use in those 3 months?
dae06 is offline   Reply With Quote
Old 10-30-2008, 10:15 AM   #11
You would have to know how many gpm each head uses. Look at the literature for your system and it will tell you that information.
My idea of a perfect day: No where to go and all day to get there.
Old 11-10-2008, 09:39 AM   #12
Well, don't knoiw that, but here is another question.
How many gallons would it take to cover a 5000 square foot area with a half an inch (1/2") of water?
I try to water a 1/2 inch per zone, twice a week.
Old 11-10-2008, 09:45 AM   #13
I think it's 7.8 gal/cuft, so around 1600 gallons per watering.
jerryh3 is offline   Reply With Quote
Old 11-10-2008, 10:02 AM   #14
That would be awesome if I could get by that cheap, but let me figure out a formula., I thinks it's much more that that.
Old 11-10-2008, 10:21 AM   #15
Which formula? 5000*(1/24)*7.5(correct number, I think)=1562.
More On This Topic
Hi! I'm Cathi Pare with the City of Santa Barbara Water Resources speaking to you today for expertvillage.com. We've already looked at the meter and we determined that there was water running through the meter so the next step is we want to isolate is it... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking all of our exterior faucets. First off you want to make sure that you disconnect all hoses so that they don't freeze and cause a pipe to break. The next thing I'll do is I... Read More »
Hi! I'm Cathi Pare, City of Santa Barbara Water Resources Department speaking to you for expertvillage.com. We've been talking about ways to check for water leaks to be more conservation minded in your house and more water efficient overall. One of the... Read More »
Hi! I'm Arnesia Frances from Bell Nursery in Burtonville, MD for Expert Village. We are going to help you get your garden ready for the Winter. This is probably going to be the last time that I water out here because it is really starting to get cold and... Read More »
I'm Cathi Pare, water resource specialist in the city of Santa Barbara speaking to you today with expertvillage.com. We've done our water check. We've determined that we got a leak somewhere from the house out. It's not in the supply line by shutting it... Read More »
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
Need to add a "Blue Light" to my water system AlbrightPM Plumbing 2 12-02-2006 06:29 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
