Where To Drain My Under Ground Gutter Piping? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 05:11 PM   #1
Where to drain my under ground gutter piping?
Can I run my detached garage gutters into the sewer pipe comming from my house?
E-man1 is offline   Reply With Quote
Old 05-09-2012, 05:41 PM   #2
Rewards Points: 1,548
In practically all cases, no.
Never into a sewage line going to a septic tank or other on-site sewage disposal system.
Almost all cities prohibit running gutter water or ground water or rain water into the sanitary sewer. Some cities let you drain to a storm sewer which is a separate system from the sanitary sewer.
Acceptable places to drain underground gutter collector piping:
1. Into a pit where a sump pump sends it away from the house,
2. Into a dedicated leach field (which can be constructed in the same manner as a French drain, in the same manner as a septic tank leach field, or any method in between),
3. Terrain permitting, a down sloping undrground pipe that eventually reaches the surface.
Old 05-09-2012, 07:27 PM   #3
Wow!! Fast response!! Thanx allanj, very helpful and much appreciated!!
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
Resurfacing a ground level deck, needing to drain water gamesinthebasem Building & Construction 0 07-10-2011 06:11 PM
Comment on drain piping plan, please JohnstownFlood Plumbing 0 03-14-2011 06:13 PM
Under ground wiring on top of pvc water piping. mcmad2 Electrical 11 08-09-2010 08:02 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
