Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-22-2011, 01:40 AM   #1
Where does patio drainage go to?
Sorry for a newbie question but I have been trying to figure out where runoff on a future paver patio would drain to.
The pavers will be in my backyard and I can only think that I need to run a long pipe from the backyard to the front yard, drill a hole through the sidewalk and drain it to the gutter.
Is this correct, or am I overthinking this?
Thanks in advance.
Chris
chrisngo is offline   Reply With Quote
Old 09-22-2011, 07:44 AM   #2
The primary part of this two part discussion is a decision. The figuring-out comes second.
Is the back yard high enough that an underground pipe will slope down all the way to the front yard and still slope down when it reaches the gutter?
You may need a pumping station (a pit with a sump pump) somewhere in the middle like more in the front yard.
Tunneling under a sidewalk, even for a 3 inch diameter hole, can be tricky without weakening the sidewalk.
If you made a subtle wide ditch (a swale) in the lawn, would the water flow out to the front without an underground pipe?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 09-22-2011, 09:59 PM   #3
There is a downward slope that starts going towards the street. Is there any way to divert the drainage without having to drill a 3 inch hole through the sidewalk?
Chris
Old 09-22-2011, 10:02 PM   #4
Learning by Doing
Leah Frances's Avatar
Chris - you need to talk to your local municipality. In many places it is illegal to simply divert it over the curb. They will be helpful in letting you know which route you should take. Then we can help you figure it out!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Patio drainage Gazza1976 Landscaping & Lawn Care 6 06-11-2011 10:37 AM
Concrete Patio drainage issues kozmo99 Building & Construction 3 06-20-2010 10:49 AM
drainage issue on patio supaflyz Landscaping & Lawn Care 1 08-18-2009 02:44 PM
Drainage for my paver patio rabih_00 Landscaping & Lawn Care 12 08-26-2008 04:58 PM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 06:27 AM
