-   -   Where does patio drainage go to? (http://www.diychatroom.com/f16/where-does-patio-drainage-go-117981/)
chrisngo 09-22-2011 12:40 AM
Sorry for a newbie question but I have been trying to figure out where runoff on a future paver patio would drain to.
The pavers will be in my backyard and I can only think that I need to run a long pipe from the backyard to the front yard, drill a hole through the sidewalk and drain it to the gutter.
Is this correct, or am I overthinking this?
Thanks in advance.
Chris
AllanJ 09-22-2011 06:44 AM
The primary part of this two part discussion is a decision. The figuring-out comes second.
Is the back yard high enough that an underground pipe will slope down all the way to the front yard and still slope down when it reaches the gutter?
You may need a pumping station (a pit with a sump pump) somewhere in the middle like more in the front yard.
Tunneling under a sidewalk, even for a 3 inch diameter hole, can be tricky without weakening the sidewalk.
If you made a subtle wide ditch (a swale) in the lawn, would the water flow out to the front without an underground pipe?
chrisngo 09-22-2011 08:59 PM
There is a downward slope that starts going towards the street. Is there any way to divert the drainage without having to drill a 3 inch hole through the sidewalk?
Chris
Leah Frances 09-22-2011 09:02 PM
Chris - you need to talk to your local municipality. In many places it is illegal to simply divert it over the curb. They will be helpful in letting you know which route you should take. Then we can help you figure it out! :thumbup:
