What To Use For Better Drainage Under Flower Pot? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-09-2013, 09:49 AM   #1
Rav
Rewards Points: 552
What to use for better drainage under flower pot?
See pics below. I have a long rectangular flower pot which sits on the ground, surrounded by a slate-topped retaining wall on the left and a slate walkway on the right. There are a few inches of mulch immediately around the pot. The pot contains new potting mix. It isn't draining properly out of the bottom holes, though. Right now there's just mud underneath, which clogs the holes. What's an easy solution to promote better drainage under the pot? I was thinking a layer of sand (which I have on hand), or perhaps very small pebbles of some type, but I wanted to check here first before using the wrong thing. How thick a layer should I use, and of what? Thanks.
What to use for better drainage under flower pot?-cimg3173.jpg   What to use for better drainage under flower pot?-cimg3176.jpg
Rav is offline   Reply With Quote
Old 07-09-2013, 11:11 AM   #2
Rewards Points: 12,876
I would clean out that area and use some decorative stone not sand.
Old 07-09-2013, 12:37 PM   #3
Rav
Rewards Points: 552
Thanks, Joe. Do you mean replace the mulch around the pot with the stone too, not just for under the pot? I'm concerned that the stone would retain a lot of heat and reflect to the flowers. At any rate, if I do what you're suggesting, would something like this work:
www.homedepot.com/p/Vigoro-0-5-cu-ft-All-Purpose-Decorative-Stone-54775V/202026926
Old 07-09-2013, 04:33 PM   #4
Rewards Points: 444
Could some tell me what is wrong that the last few words of text and a portion of the pic on this post is covered by a post by skyroofers titled "My best ever project" 04-11-2013 and a post by jfrance "Basement stairs" 05-05-13. Those two items don't follow the replies and obscure them but only the original post. thanks
Old 07-09-2013, 04:41 PM   #5
Rewards Points: 2,040
that started happening when changes were made on this site.
I found that if I 'minimize' or shrink the page, then the column on the right doesn't overlap. Of course you have to squint to read the post.
Startingover is online now   Reply With Quote
Old 07-09-2013, 05:05 PM   #6
I agree with Joe, some river rock would look better there.
In the future when planting in pots, its best to allow for drainage inside the pot. Take some broken pieces of an old clay pot or stones and place them over the drainage holes before adding soil. For now, just poke a stick up the bottom holes to get that water moving before your flowers rot.
creeper is offline   Reply With Quote
Old 07-09-2013, 07:20 PM   #7
Rav
Rewards Points: 552
I want to be clear: I understand that you're saying to use decorative stone/river rock around the pot, but can I also put it under the pot in order to enhance drainage? Thanks.
Old 07-09-2013, 08:04 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 842
I line the bottom with landscape cloth....keeps the dirt in....lets water out....
ddawg16 is online now   Reply With Quote
Tags
drainage , flower , pot
Foundation Drainage bhry Building & Construction 3 09-23-2010 11:08 AM
Pool Surround Drainage Questions Ynot General DIY Discussions 3 06-07-2010 04:53 PM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 01:05 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 02:22 PM
Drainage Question bassaway Landscaping & Lawn Care 5 05-05-2009 02:17 PM
