What Type Of Grass Is This? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-30-2013, 07:49 PM   #1
What type of grass is this?
What type of grass is this? Or is it a bad grass? I have couple square feet of it in my front yard. Thanks.
elietabet is offline   Reply With Quote
Old 05-01-2013, 11:07 AM   #2
I guess nobody knows
Old 05-01-2013, 01:51 PM   #3
Rewards Points: 93
You posted it less than 4 hours ago. Give it time.
7 VII 7 is offline   Reply With Quote
Old 05-02-2013, 10:27 PM   #4
seansy59's Avatar
Rewards Points: 258
You have rye grass. Very common, and very good grass.
Common good grasses are Perennial/or Annual Rye Grass, Fescue, and Kentucky Blue.
seansy59 is offline   Reply With Quote
Old 05-02-2013, 10:33 PM   #5
Thanks for the reply.
I actually meant the ones that have what looks like seed on the tip of the blade.
Is that still rye?
Old 05-02-2013, 10:47 PM   #6
Is that still rye?
Those don't just look like seeds, they are seeds!
That is grass that has gone to seed.
If it just in a small area, and not the rest of your lawn it is possible that a different grass variety that seeds at a lower height might have been used at some point to patch an area.
A fun fact is that Kentucky Blue grass gets its name from the fact that when it grows to between two and three feet, it will have blue flowers heads.
oldhouseguy is offline   Reply With Quote
Old 05-02-2013, 10:57 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
elietabet.....this is a good example of why it helps to put your location in your profile.
Welcome....
Old 05-02-2013, 10:58 PM   #8
The neighbor said it might be annual bluegrass and is considered weed grass like crabgrass, and I should have it gone.
I know my grass has more than 2 different type of grass, previous owner didn't take good care of it, and I'm trying hard to have a decent lawn.
I live in Indiana if that makes any difference.
Old 05-03-2013, 01:38 AM   #9
Rewards Points: 156
In Indiana:
Mow high, mow often.
Aerate once a year.
Add some compost in the fall, if you can (especially if you live in an area with clay soil)
Have the local Purdue extension test your soil Ph, and then treat it with whatever they recommend in order to get your Ph in range.
I've you've got a huge problem with the annuals, you can hit them with a pre-emergent herbicide in the spring. Since they're already "up" for the year, forget about them for now and focus on doing the above to get the rest of your yard healthy. If you've got strong perennial grass, the annuals don't stand much of a chance in the spring when they try to come up.
PS, fellow Hoosier here, from Columbus. Currently living in Beijing, China. I live in an apartment, so I don't have any grass to care for. But I've got 1.6 acres waiting for me when I go back home in 2 years.
moondawg is offline   Reply With Quote
Watering your grass UMWolve Landscaping & Lawn Care 2 03-25-2012 05:34 PM
Grass Barry J Landscaping & Lawn Care 2 02-22-2012 01:30 PM
What is wrong with my Bermuda Grass: Infected With A Fungus? rkanemeier Landscaping & Lawn Care 8 11-20-2011 07:19 PM
How to identify lawn grass types findlay70 Landscaping & Lawn Care 1 07-06-2010 08:10 PM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
