What Is This Top Post Called - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-22-2014, 10:45 PM   #1
What is this top post called
My neighbor house has this post with a nice square top. What do you call this? I have 4 brick post in my home without any top. Would it be expensive to do it? Thank you.
bluesky2014 is offline   Reply With Quote
Old 02-23-2014, 01:18 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
Post cap?
Expensive? If your having to ask..chances are it would be more expensive than you want to pay. Lots of stone cutting there.
Old 02-23-2014, 11:15 AM   #3
Rewards Points: 240
the edge looks rounded. perhaps they have pieces or kits.
Fix'n it is offline   Reply With Quote
Old 02-23-2014, 11:43 AM   #4
DL's husband's Avatar
The top of the post is called a cap.
The expense would be the availability of the masonry you have. Cutting it can be done with a masonry blade attached to a circular saw (use eye protection and a dust mask) to cut the pieces to size.
DL's husband is offline   Reply With Quote
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
Post problems WillK Building & Construction 8 03-28-2011 06:16 PM
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 03:28 PM
