What Is This Stuff? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-07-2009, 04:08 AM   #1
Rewards Points: 109
What is this stuff?
BimmerRacer is offline   Reply With Quote
Old 09-07-2009, 04:24 AM   #2
Familyman
what state are you in does it die out in the winter or extreme heat
when you break the vine does it have a strong odor
matt700 is offline   Reply With Quote
Old 09-07-2009, 08:01 AM   #3
Rewards Points: 109
Maryland
It's growing like crazy all over our property, up trees, bushes, you name it. I do not recall seeing it in the previous years, at least not anywhere near this much. We did have a lot of rain this year.
I have not noticed the odor, I'll check later today
Old 09-07-2009, 02:57 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
Kudzu
Old 09-08-2009, 08:29 AM   #5
Yowza
I didn't realize kudzu flourished that far north! It's a pain in the if that's what it is.
Kudzu roots are obnoxious and don't die easily. The vine seeds like mad. Out of control, it kills most everything under it.
If it's kudzu, you could try removing it by the root to get rid of it or keep it cut back to the root so it won't spread and seed. Down here, chemicals are used, but this only seems to kill the foilage as new green vines grow up through the dead stuff. Cold can kill the roots. It doesn't get cold enough down here for that, but maybe up there winter wipes it out.
Tess is offline   Reply With Quote
Old 09-08-2009, 08:57 AM   #6
Another imported vine that is extremely invasive
http://www.maxshores.com/kudzu/
Old 09-08-2009, 06:32 PM   #7
Don't know it all, yet!
Must be some of that D*** Yankee kudzu. Nothing like the kind we have here in Gawja!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Black stuff under thinset? Osiris Flooring 1 04-04-2009 04:09 PM
Great stuff around boxes? jamiedolan Electrical 6 12-15-2008 03:07 PM
Great Stuff question amakarevic Building & Construction 14 01-02-2008 10:28 AM
foam like Great Stuff that is waterproof amakarevic Building & Construction 1 12-30-2007 08:52 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
