What Sprinkler Pipe Material Under Driveway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 12:13 PM   #1
Rewards Points: 41
What sprinkler pipe material under driveway
I'm going to install a lawn sprinkler system this spring. It will include buried lines from a rainwater harvesting cistern. One zone will be across the gravel driveway from the cistern, so the water line to that zone must withstand normal vehicle loads.
What materials would be satisfactory? How deep would that segment of the line have to be?
Would PVC pipe no more than a foot below grade do the job? My sense is it would not.
tomseeley is offline   Reply With Quote
Old 01-29-2011, 01:23 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... Of the Many driveways I've paved,...
We just bury a length of 2" PVC to run the system tubing through....
It's always from a few inches, to a foot deep,... Never more...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
tomseeley (01-29-2011)
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 04:51 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
