What Fence Will Preserve A Hillside View? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 03:58 PM   #1
Rewards Points: 77
What Fence will Preserve a Hillside View?
We want to replace or repair our current fence. We want the fence to blend in or be "invisble." Whatever IS seen, we'd like to be tasteful.
What type of fence and what color would you recommend? (e.g., galvanized or black or???) Also pictures you can provide us are appreciated, but not necessary. Thank you!
We have a 1/3 of an acre hillside lot. The lower yard is about 4 feet (near side) to 10 feet (far side) lower than the upper yard.
The lower yard currently has a galvanized chain-link fence (posts but no header or footer bars between the posts). Deer jump over the fence (often to get out, bending sections of the chain-link) and cats, moles, skunks and raccons likewise invade (perhaps underneath or through some of the holes in it).
One more thing: We must keep a gate to gain access to the lower yard from a wood chip covered service road along the lower run of the fence. So the construction around the gate must accomodate/permit/incorporate about a 16 ft wide gate.
1655graff is offline   Reply With Quote
Old 04-09-2012, 06:43 PM   #2
biggles's Avatar
photobucket a pix up here..... from the back looking out and we'll give you suggestions...copy the photo then to post it here type>[img]..then hit edit up top and PASTE...[/img]<type after pix ID just in case you don't know how...
Old 04-11-2012, 02:28 PM   #3
Rewards Points: 77
Huh?
I am not sure whether you tried to post a pic or are asking us to do so.
And, if the latter, how does a pic of the view do more than satisfy your curiousity? We could accomodate, but maybe the question needs to be more specific, namely:
Is a galvanized deer fence less visually intrusive or more visually attractive/pleasing than black chain-link fence?
or...
What kind of fernce is typically recommended for hillsides with views and why/what's the rationale behind the recommendation?
Old 04-11-2012, 02:30 PM   #4
Too Short? Cut it Again!
If you have the money lexan or glass will work.
Old 04-11-2012, 04:00 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
How about a low rock wall with wrought iron fencing along the top of wall?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 1 10-10-2013 01:33 AM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Backyard Fence (Part 1) biggidybankston Project Showcase 20 12-05-2010 12:44 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
