-   -   What to do where cultured stone veneer meets grass (http://www.diychatroom.com/f16/what-do-where-cultured-stone-veneer-meets-grass-48357/)
shleppy 07-07-2009 09:48 PM
I have a cinder block wall that I am going to cover with cultured stone veneer and I am wondering how to deal with the veneer at the bottom of the wall where the grass butts up against the wall. If I install cultured stone veneer on the wall, I'm concerned about grass growing into the veneer (where it meets the grass) and I'm also concerned about damaging the stone veneer with my mower when I mow the lawn periodically.
How is one supposed to install the veneer and protect it at the same time?
I was thinking that I should have a small mowing strip poored at the base of the retaining wall, and then install the stone veneer down to an inch or two above the mowing strip. The mowing strip would serve 2 purposes:
1 - Provide a "clean" termination of the veneer install
2 - Protect the stone veneer from getting banged into by my mower and or edger.
Is the the right approach or is there a better way to deal with this?
Lali 11-09-2009 04:29 AM
Haven't a clue what you're talking about, but seems to me you have given yourself the perfect solution. Hope it works. Good luck & God Bless! :)
mrs5150 09-02-2014 03:13 AM
Small strip like the garage floors have(cement strip/step)? I am thinking thats what your talking about. But since you already have grass there why don't you plant some small plants…that will cover the mowing strip you want to place.
Fix'n it 09-02-2014 08:12 PM
use some other, cheaper, stone/brick/whatever, for the bottom 6".
Bud Cline 09-02-2014 10:27 PM
Are you talking about the retaining wall type cultured stone?
noquacks 09-03-2014 06:39 PM
You could spray surflan pre emergent liquid to "poison" that sprayed area- grass wont grow there for maybe 6 months, depending on many factors. This is assuming the grass is from seeds dropped from parent grass. If runners, surflan wont help- use in combination with round up. yes, dead grass.
