Wet Planter Box Against House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 08:53 AM   #1
Wet planter box against house
How do I keep water from settling in a concrete planter bed against my house? I was told by a friend of mine I should dig down about 8 inches and fill it with gravel. It is a concrete foundation with no basement and I am in northern California.
Thanks!
dgreenin408 is offline   Reply With Quote
Old 06-18-2011, 08:56 AM   #2
Too Short? Cut it Again!
Some details are missing from your post? What do you mean by "here."
Old 06-18-2011, 09:02 AM   #3
I fixed it, sorry
Couldn't figure out the attachment.
Old 06-18-2011, 09:24 AM   #4
Think I got it. It is too bad the planter is to be right up against the house but no big difference I guess.
It looks like the patio slopes a way from the house. You will want to make sure the planter does too. I don't see that you gain anything with gravel. You do not want to drain the base of the planter over the patio or you are likely to stain it.
It would say put drip irrigation in the planter so as to minimize the amount of water going in at one time. Not much you can do about rain and so forth. You might think about some sort of splash guard behind the planter to keep splattering from the soil on to the wall surface minimized.
How tall will the planter be (not that it makes any difference I guess)? Make sure the planter itself drains well. Might want a layer of gravel in it and extra drain holes?
Old 06-18-2011, 09:34 AM   #5
Thanks. Im thinking that with the gravel, water will pool below the surface level of the floor inside. Maybe no difference. If the drain rock would be ineffective, then I would probably just plant right in the dirt.
Old 06-25-2011, 01:02 AM   #6
Ideally you want to keep water tables below the drip screed, stucco actualy sheds mositer through the screed metal at the bottom of the house (where plate line meets the slab). If you elevate your planter bed you should use a berrier against the house like a rubber membrane. You should also install a French drain against the house and below grade. Excess water will seep down that French drain and stay away from your house. I'd also paint that sedition before installing the membrane with elastic water proof paint.
ABAR is offline   Reply With Quote
Old 06-25-2011, 08:57 AM   #7
So my rock idea wont cut it, you think? From what I understand, a french drain would require digging up the patio to route the drain pipe, right? That is more work than I could do now...
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 02:24 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
