Wet Back Yard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 07:00 PM   #1
wet back yard
Last fall i had a 24x48 patio laid. There has been standing water near the back /middle of the yard. How can i get rid of the puddles in the yard so I will be able to fully enjoy the patio and yard.
helpnbrandywine is offline   Reply With Quote
Old 03-07-2011, 07:03 PM   #2
waterman1971's Avatar
Rewards Points: 150
I would start digging
waterman1971 is offline   Reply With Quote
Old 03-07-2011, 09:04 PM   #3
Rewards Points: 1,442
You may need to regrade the land so the water runs away.
Old 03-08-2011, 07:11 AM   #4
Think gravity. Whatever water doesn't soak into the soil, gravity puts it wherever it can. What is the terrain like, pot holes or low spots?- fill them in. Did they alter the lawn when the patio was installed, create a ridge or ruts with a backhoe? Fill in areas slowing over time with a rich topsoil or sand to let gravity take all the water off your property. If you want it fixed this year and it isn't potholes, rent a sod cutter, add the topsoil, then replace sod.
sippinjoes is offline   Reply With Quote
Old 03-08-2011, 07:19 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... It's gotta be graded so it drains...
Water flows downhill...
Garage framing rotted, back side dropped 3" zetti1102 Building & Construction 12 08-06-2009 09:18 PM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 07:44 AM
How do I know if it's safe to grow vegetables in my back yard? dragonness Landscaping & Lawn Care 8 07-24-2008 09:30 AM
Does All Solar Lighting in Back yard really work? KUIPORNG Landscaping & Lawn Care 11 05-27-2008 03:36 PM
Back Yard Surfaces EAMVT94 Landscaping & Lawn Care 7 03-29-2005 11:52 AM
