Well Switch - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 02:52 PM   #1
Rewards Points: 2,038
well switch
After being in my new home 6 weeks I just discovered an "on/off" switch on the well in my back yard.
So far the well hasn't worked which isn't a problem as I'm not using irrigation. But I planted a lot of things and it might be nice to use that water.
What will happen if I flip the switch on? I'm a little nervous about it wondering if something will happen that I can't undo. The switch is near the faucet. Actually I'm doubting the pump even works but am curious about this switch.
thanks
Startingover is offline   Reply With Quote
Old 07-12-2012, 03:24 PM   #2
MarginallyQualified
Rewards Points: 2,464
What you thought was the cap for the well will slide over allowing
the ICBM buried in your backyard to launch. (Well, it could)
Old 07-12-2012, 04:47 PM   #3
tarheel, just watched the video.............LOL.
Now I'm REALLY nervous about touching that switch. (but still curious).
Old 07-12-2012, 05:06 PM   #4
Too Short? Cut it Again!
What is on the output side of the pump and where is the outlet? What does the well water get pumped into?
I think you should figure that out before flipping switches.
Is your home water supply from well water or from a municipal source.
The Following User Says Thank You to user1007 For This Useful Post:
Startingover (07-19-2012)
Old 07-12-2012, 05:26 PM   #5
sdsester,
I'm on city water.
I was just planting flowers around the well, (to disguise it) and on the side where the spigot or faucet is I noticed a covered switch plate, like on my outside outlets. I opened it and discovered the switch that looks like a light switch.
Old 07-12-2012, 08:22 PM   #6
Bridge the open switch contacts with a 100W bulb. If it lights full brightness (use a multimeter to confirm full line voltage) there is a short downstream of the switch.
If it burns out the well runs on 240v.
Maybe you should check the voltage before you put the bulb in.
The Following User Says Thank You to Yoyizit For This Useful Post:
Old 07-12-2012, 08:34 PM   #7
Rewards Points: 3,350
No guts ,no glory,go ahead and flip it,and let us know what happened,if your able!
Canarywood1 is online now   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
