Weigh Down Patio Furniture - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-11-2013, 05:31 PM   #1
New House Newbie
Rewards Points: 95
The wind always seems to be blowing here and my aluminum chairs get blown around my deck. I am trying to think of something that I can weigh down the frame of the chairs. They are hollow aluminum with slign fabric and I thought if I could drill a small hole in each chairs base, I could pour or add weight that way and just put a plug in the hole. I first thought of bb's from a bb gun. Not sure if that would add enough weight. Then I got to thinking some sort of liquid that would solidify. It would have to be very runny as the hole I am thinking of drilling would be no bigger than say 3/8". All the searches have people putting sand bags or pieces of concrete, or one said to drive a screw through the chairs base into the deck (not going to happen). Anyone have any ideas that they can think of.
Don't know if a picture would help in this case, but I could snap one if wanted.
C_J_GO is offline   Reply With Quote
Old 10-11-2013, 05:58 PM   #2
Rewards Points: 12,808
Buy better made heaver chairs.
Old 10-11-2013, 05:59 PM   #3
"You can do anything"-Mom
brockmiera's Avatar
Post a picture of your chair. I'd love to come up with a good idea.
brockmiera is offline   Reply With Quote
Old 10-11-2013, 06:17 PM   #4
Bill Kearney
Rewards Points: 1,174
Sand bag is the least hassle.
Filling the chairs runs the risk of whatever hole you put in them reducing the strength of that section of tubing. You'd want to avoid using a different metal as you'd run the risk of corrosion. Better to use sand or something, not that I think filling them would be anything like a good idea.
wkearney99 is offline   Reply With Quote
Old 10-11-2013, 06:19 PM   #5
New House Newbie
Rewards Points: 95
Here they are.
Weigh Down Patio Furniture-image-3521043614.jpg   Weigh Down Patio Furniture-image-4188340845.jpg
Old 10-11-2013, 06:24 PM   #6
brockmiera's Avatar
I think that if you were to drill a hole in the back there and fill the base with sand it would be a good start. You can and should find a rubber grommet that will fit it before you drill the hole. If sand isn't heavy enough then you could definitely do wet cement. (concrete minus aggregate)
Old 10-11-2013, 06:29 PM   #7
New House Newbie
Rewards Points: 95
I will try sand first. Just need to get fine sand with a small funnel I suppose. I will try it and report back.
Old 10-11-2013, 06:38 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 348
I'd fill it with lead- but then I have the tools to melt lead and pour it.
Lead is dense and heavy, wouldn't take much
Old 10-11-2013, 09:30 PM   #9
Rewards Points: 396
I would do a volume / weight calculation before attempting to fill with anything other than lead because I'm not seeing much advantage with sand. Lead shot may benefit only filled in the base area if the price ever gets so one could afford it.
I filled round tubing chairs with a hydraulic cement for a reason other than weight and I doubt it made a 2 lb. difference.
SeniorSitizen is offline   Reply With Quote
Old 10-12-2013, 05:19 AM   #10
Bill Kearney
And in seeing a picture of the chair I don't think it would help much here either. It doesn't look like there'd be enough open space in there to hold anywhere close to enough volume of reasonably accessible material to make a difference.
Old 10-12-2013, 07:58 AM   #11
Rewards Points: 6,089
Originally Posted by C_J_GO View Post
Here they are.
check this out...weight discs...under select by item -- they have a set of 20
for 61.00. each disc is 2.2 lbs. that would be 4.4 lbs for each chair.
glue one disc on each back corner with gorilla glue..If it's not
enough weight -- double it up.
You have a gorgeous deck.
http://www.power-systems.com/p-4806-...FUOe4Aod-n8ATA
Two Knots is online now   Reply With Quote
Old 10-12-2013, 09:07 AM   #12
Rewards Points: 140
buy stackable chairs. stack them out of the way when not in use.
Fix'n it is offline   Reply With Quote
Old 10-18-2013, 01:03 PM   #13
Rewards Points: 91
Agreed that filling with anything probably won't make a noticeable difference in weight. You're probably better off physically attaching some weight to it. Small sandbags are going to be the most cost effective.
NegativeTen is offline   Reply With Quote
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 06:20 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Teak patio furniture jontalbot General DIY Discussions 2 08-27-2011 11:19 AM
Teak vs. Eucalyptus for patio furniture drlsubaru Landscaping & Lawn Care 4 10-31-2009 07:06 AM
