Weeping Tile Along Fence Line - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 03:28 PM   #1
Weeping tile along fence line
Hello All,
First of all, I'm new to this forum and am happy to find like minded people.
I live in southern Ontario in a new subdivision.
My neighbours backyard behind me is about 4' higher than mine. Currently there is a drainage ditch running down the property line in order to weep water from the backyards to the front. Currently the ditch works good and I'm having no water issue.
My neighbors have started building fences (6x6 posts) on the property lines, therefore interupting the flow of the water in the ditch. As a precaution I'm considering running weeping tile on my side of the fence in order to ensure the water can drain properly.
Has anyone ever done this? If so, any pics to help me along? I don't want to have loose gravel along my fence lines; I'd prefer it to stay grass. Is it possible to run a weeper with gravel under the grass?
Any thoughts/comments are appreciated.
Huck2013 is offline   Reply With Quote
Old 04-23-2013, 04:12 PM   #2
DIY staff
Rewards Points: 7,174
Unless the fence is acting like a dam, the water should still flow in the same fashion---have you experienced problems yet?
Old 04-24-2013, 11:07 AM   #3
I havent' experienced it yet on my side; but I can tell my neighbour has already 'damed' his side up.
I'm thinking more proactively. The drain ditch is only about 5" deep and maybe 8" wide. The fence posts are 6x6 so I'm sure it's going to dam up.
I'd rather put in the weeper now when everything is dug up than retrofit it later after the fence is put in.
But I see your point, dont' fix it unless it's broken. I guess it's 6 in one and half-dozen in the other.
The Following User Says Thank You to Huck2013 For This Useful Post:
oh'mike (04-24-2013)
Tags
drainage , weeping tile
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
remove weeping tile when installing new patio? TC5 Concrete, Stone & Masonry 0 07-25-2012 02:53 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
weeping tile Mike in Leduc Plumbing 2 07-11-2010 08:26 PM
Weeping tile basics hellothere123 Plumbing 4 07-06-2010 11:39 PM
