Weedwacker Problems - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 04:17 PM   #1
Weedwacker problems
using a craftsman weedwacker, starts up fine, but when its moved to run or i hit the throttle to give it gas it kicks out...
any suggestions would be greatly appreciated
dynamo Nation is offline   Reply With Quote
Old 05-13-2012, 04:22 PM   #2
Rewards Points: 13,712
90% of the time it's the carb dirty. Rebuild it or replace the whole thing.
You did dump the old last years fuel and add new fresh fuel, right?
Old 05-13-2012, 04:36 PM   #3
Actually I did not remove the old gas, guess thst could be a problem...
would cleaning it work?
Old 05-13-2012, 05:29 PM   #4
A Little Of Everything
Rewards Points: 1,364
2-cycle gas (mixed with oil) is notorious for crapping up over the winter.
I'd suggest you start by dumping out the old gas, and putting in new gas/oil. If you can get the weed wacker to start at all, that's your best best. Let it run at idle as long as it will, slowly try to increase the speed after it warms up. There's a good possibility that the new gas will clear stuff out and the thing will be fine.
If not, you'll need to pull the carb apart and clean it.
DrHicks is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Owen or Certain Teed has less problems?? reeses Roofing/Siding 10 02-07-2009 08:35 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 08:09 AM
steam heat problems alanliz HVAC 8 01-18-2009 08:10 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
