Weed Trimmer Starts Then Turns Off - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 06:05 PM   #1
Weed Trimmer starts then turns off
I have a JD BC1900 weed whacker that starts on the first pull but when i pull the trigger it starts to stall. I have cleaned out the carb, changed the spark plug, fuel filter line and return line as well as the spark arrester. Here is the weird part if i flip the trimmer with the gas tank facing up not down in the regular position is runs even when i pull the trigger and stays on.
I am at a lost for ideas? Any and all help would be appreciated, thanks.
Oh yeah i even mixed sea foam with the gas mixture to clean up the inside.
Fdelgado is offline   Reply With Quote
Old 10-24-2011, 08:56 AM   #2
Rewards Points: 482
the little line that is on the fuel filter is it pulled up so maybe the filter isn't down in the gas?? It should have lot's of slack. Is the line new?? this gas make's the line soft. and the little push butten is it good no chack's in it. I had to change all of this on mine. Just a thought. good luck
del schisler is online now   Reply With Quote
Gas Trimmer Recommendation polarzak Landscaping & Lawn Care 12 07-04-2011 07:28 AM
Trimmer Revs but Head won't spin leichte Landscaping & Lawn Care 1 06-21-2011 03:16 PM
Grass Trimmer Worth Repairing??? jlaustin Tools 3 08-06-2010 07:01 PM
Repair help w/ a cordless trimmer kennykenny Tools 6 06-28-2009 08:20 PM
Name of tough yard weed in FL and how to kill Ladybug1220 Landscaping & Lawn Care 3 02-16-2009 06:30 AM
