Weed Eater XR-95 Help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 03:20 PM   #1
Weed Eater XR-95 help
We are trying to put new fuel line in, because the old ones literally disintegrated. We are having trouble figuring out where the lines go, hopefully someone can help us. Thanks!
kenpachi is offline   Reply With Quote
Old 09-04-2009, 08:44 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
These are from the Hankster; for a Ryan weed trimmer Model 265 at http://www.hobbytalk.com/bbs1/showthread.php?t=147204
They are also a good group guys more than willing to help out.
I know it is not the same as yours but it may give you an idea.
Here are a couple of more from the same thread from geogrubb.
These are for a IDC 580 Supreme.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 09-04-2009, 09:55 PM   #3
brokenknee's Avatar
I could not find a free manual on line, but this is a parts list for your weedeater; 58 and 45 are listed as fuel lines.
I also copied this answer from hobby talk.
03-31-2009, 10:59 PM http://www.hobbytalk.com/bbs1/showth...l+line+routing
paulr44
iTrader Rating: (0)
My Photos
Assuming you have a primer independent of the carb.:
I never worry about which hose goes where, because I know the routing....the primer pulls fuel through the carb. and returns "waste" to the tank.
Best to work backwards....
Short fuel line from tank with no filter is the primer return. Connect this to the primer fitting that provides pressure to your finger tip.
If you can't sense the pressure to determine which fitting is which, connect a spare piece of line to one primer fitting at a time, hold the line near your ear or cheek (and press the bulb) and you should hear or feel one push air out, obviously this one will be the discharge, and thus the fuel return.
The other side of the primer goes to the carburetor.
If you had both lines off the carb. and aren't sure which goes where, connect it up anyway - it'll only work if connected correctly so just switch them if it doesn't work (providing the carb. or fuel filter aren't clogged up etc
Weed eater will not start? Jake3333 Landscaping & Lawn Care 5 01-15-2010 11:50 AM
Weed Eater Help Ricktheman Landscaping & Lawn Care 10 06-20-2009 07:52 AM
ryobi weed eater lilsara88 Landscaping & Lawn Care 2 05-13-2009 08:31 PM
weed eater repairs MDduck865 Landscaping & Lawn Care 1 04-05-2009 08:15 PM
Weed Eater Weed Wacker Prob bobo Automotive Repairs 7 08-18-2008 11:12 AM
