Weed Eater Will Not Start? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 09:23 AM   #1
Weed eater will not start?
Ryobi 725r 31cc, 15" weed eater
The unit was working fine, except the fuel line broke, so I replaced all the fuel lines. I am 90% sure they are in the correct position. The fuel goes from the tank down to the bottom of the Walbro carb, gets sucked up through and out the top of the carb, back to the fuel prime button, and back into the bottom of the fuel tank.
When I remove the hose from the bottom of the carb, fuel comes out - this should indicate fuel flow to this point - good. The fuel prime button however does not get fuel so it should mean fuel is not sucked getting through the carb. The fuel prime button does suck when I disconnect the fuel line from the top of the carb and hold my finger over the end of the fuel line still connected to the prime button, so the fuel prime button should be ok. The unit does not start and seems to be fuel related. Thanks in advance for your assistance.
Jake3333 is offline   Reply With Quote
Old 07-13-2009, 06:41 PM   #2
TooledUp
Is there a fuel filter on it--if so it may be plugged?? Is there a bowl on the bottom of the carb that you can take off to see if you are getting any gas? Have you tried spraying any ether directly into the carb and seeing if it will fire??
TooledUp is offline   Reply With Quote
Old 12-13-2009, 02:16 PM   #3
HI I have had the same problem, regarding the fuel line breaking, I replaced all the line with new lines refitted in the correct order, I have the fuel flowing from the fuel tank to carb, from top of carb through primer back to tank.
Now I also poured some fuel directly into the carb, resulting in the weed eater starting and then stalling when all the fuel has been used.
Any ideas why it will not start?
Ren
Renkeepa is offline   Reply With Quote
The Following User Says Thank You to Renkeepa For This Useful Post:
vsp (04-30-2010)
Old 12-13-2009, 07:17 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... My guess is the Carb itself is plugged internally...
That's why most weedwackers end up in dumpsters... Plugged Carbs...
Old 12-13-2009, 08:54 PM   #5
Landscaper
i would have to say the carb. but my john deere weed eater would not start so i brought it in and a Hornet made a nest in the exhaust pipe. Cleaned it out and it fired right up. Its something to look at i guess.
good luck
DBRhino is offline   Reply With Quote
Old 01-15-2010, 11:50 AM   #6
fuel , spark and compression. Put fuel in piston chamber and try to start. If it runs, it is most likely fuel diaphram
LarryS is offline   Reply With Quote
Weed Eater Help Ricktheman Landscaping & Lawn Care 10 06-20-2009 07:52 AM
ryobi weed eater lilsara88 Landscaping & Lawn Care 2 05-13-2009 08:31 PM
weed eater repairs MDduck865 Landscaping & Lawn Care 1 04-05-2009 08:15 PM
Blue smoke at start up, and shudder at idle fauer Automotive Repairs 6 08-22-2008 11:39 AM
Weed Eater Weed Wacker Prob bobo Automotive Repairs 7 08-18-2008 11:12 AM
