Weed Eater Help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 08:42 PM   #1
Weed Eater Help
I have 2 weed - eaters, echo, and craftsman that exhibit the same symptoms. I've overhauled the carburetors on them, new gas line, new filters.
And both of them act like a fuel starve when you try to rev them up. I'm befuddled. Any help would be appreciated!
Ricktheman
Ricktheman is offline   Reply With Quote
Old 06-14-2009, 10:01 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a lot of times, you will get a buildup in the mufflers that restrict flow and will act just like that. Try removing the muffler and running it (not long though, not good on things). If it improves, take a propane torch to the mufflers to burn out the oil and junk.
Old 06-15-2009, 02:40 PM   #3
47_47's Avatar
Rewards Points: 44
Good advice.
Are you running the proper ratios in each machine?
47_47 is offline   Reply With Quote
Old 06-15-2009, 05:29 PM   #4
I believe so.
Old 06-16-2009, 08:12 PM   #5
Don't know it all, yet!
Low speed mixture adjusted correctly? Sounds like too lean. If they idle OK but cough when you snap the throttle, open the mixture about 1/8 turn at a time. It's right when the engine accelerates smoothly.
With the throttle wide open, find the smoothest mixture, then back it out just a little until it just starts to growl. Not the proper terminology, but that's what it will sound like when it's right.
And I presume new sparkys?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 06-17-2009, 05:42 PM   #6
I have messed with the mixture valves, cant seem to get a good response. Of course the needles have those red and yellow caps on them that limit how much you turn them. Yes I have put in new plugs.
Thanx
Old 06-17-2009, 05:51 PM   #7
nap
You talking to me?
nap's Avatar
did you do the muffler thing?
Old 06-17-2009, 05:53 PM   #8
Yes, didnt seem to help, at least on the Echo weedeater. Havent tried it on the Ryobi yet.
Old 06-19-2009, 09:45 AM   #9
Kinda Handy
I take the restrictor caps off of mine, my craftsman chainsaw and both of my poulan weed eaters ran like out of the box.
the way I adjust these little engines is to get'em goin wind them right out turn mixture screw till it screams then back the other way till it just starts to stumble a little then set the screw in between these 2 points.
I set the low screw untill I get nice acceleration. works for me
Suzuki91vx800 is offline   Reply With Quote
Old 06-19-2009, 12:50 PM   #10
Restrictor Caps
Dear Sir, thanks for the suggestion. I will definitely try that.
Old 06-20-2009, 08:52 AM   #11
not sure on the model, but along same lines Nap suggested, I had one where the spark arrestor on the muffler was clogged, it would bog down when you goosed it, someone told me to throw away the screen, I did it ran fine.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
ryobi weed eater lilsara88 Landscaping & Lawn Care 2 05-13-2009 09:31 PM
Weed Killer cgoll Landscaping & Lawn Care 3 05-09-2009 11:17 AM
weed eater repairs MDduck865 Landscaping & Lawn Care 1 04-05-2009 09:15 PM
Name of tough yard weed in FL and how to kill Ladybug1220 Landscaping & Lawn Care 3 02-16-2009 07:30 AM
Weed Eater Weed Wacker Prob bobo Automotive Repairs 7 08-18-2008 12:12 PM
