Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-13-2012, 12:43 PM   #1
weed eater heavy brush blade attachment
**edited** will this work (safely) for attaching blade to weedeater if I find a nut to fit? thanks
weed eater heavy brush blade attachment-weed-001.jpg   weed eater heavy brush blade attachment-weed-002.jpg   weed eater heavy brush blade attachment-weed-003.jpg
ugabulldog is offline   Reply With Quote
Old 10-13-2012, 01:33 PM   #2
sdsester's Avatar
How much do you have to clear? Would renting something for a day or weekend make more sense than buying a kit? I think when you get near 1/2" with no matter what special attachment you are at the upper limits of the capabilities of a weed eater? Most of the motors are just not built to deliver torque and other properties needed for very much work on things that thick.
sdsester is offline   Reply With Quote
Old 10-13-2012, 02:46 PM   #3
I need it on an ongoing basis.... have used the circular saw method before and it worked great, just wondering if that is overkill or maybe the best way, thanks.
Old 10-13-2012, 06:06 PM   #4
A Little Of Everything
Whoa - that scares me, and I don't scare easily!
Here's what I'm thinking...
First of all, there's no way in the world to make that completely safe. Period. But since you're a guy, and you want to do it, you'll do it anyway. Therefore, the need is to minimize risk.
One thing I see is that the arbor in the blade is larger than the shaft of your weedeater. You're going to need a sleeve shim, and it's going to have to be a precise fit, or the blade is going to be terribly out of balance. It looks like you're also going to need a reverse-thread lock-nut. A hardware store is probably your best bet for that stuff, but it's a long-shot.
Keep in mind that those weedeaters spin at a VERY high rpm. If anything goes wrong, it's probably going to go wrong in a big - and very painful - way.
Good luck.
DrHicks is offline   Reply With Quote
Old 10-13-2012, 08:34 PM   #5
A steel blade with sharp edges, spinning at 10,000 RPM, just a little off-center on the mounting arbor, and you are whacking it against branches and brush. What could possibly go wrong?
SPS-1 is offline   Reply With Quote
Old 10-13-2012, 08:45 PM   #6
Ummm, Doc, I think I may need a few stitches.
Old 10-13-2012, 09:19 PM   #7
firehawkmph's Avatar
Bulldog,
I used to have a blade setup for a commerical weadeater that was made for the unit. I used it once and took it off. Quite a bit of kickback, too dangerous in my opinion. If you decide to use yours, get some very heavy boots.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 10-14-2012, 05:58 AM   #8
Originally Posted by firehawkmph View Post
Bulldog,
Mike Hawkins
ok, thanks all...guess Il go another route!!
attaching circular blade to weedeater ugabulldog Landscaping & Lawn Care 1 09-25-2012 08:27 PM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 05:55 AM
ryobi weed eater lilsara88 Landscaping & Lawn Care 2 05-13-2009 09:31 PM
weed eater repairs MDduck865 Landscaping & Lawn Care 1 04-05-2009 09:15 PM
Weed Eater Weed Wacker Prob bobo Automotive Repairs 7 08-18-2008 12:12 PM
