Waterfall Help Needed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 12:35 PM   #1
Waterfall help needed
I'm making a sort of "beach" landscaping project around our hot tub.
I'd like to have a small waterfall there. I can't really envision what type of waterfall setup would look best.
Haven't seen too many rocks/waterfalls when I've been to the Florida beaches. At this point I'm thinking I'd like to maybe create something out of glass blocks and let the water run down over them. some turned vertically, some horizontally...etc.to get a waterfall effect.
Not sure, just thinking outside of the box.
Anybody ever done anything like that?
If not, or haven't seen a glass block waterfall, in order to keep with the beach project, what would you suggest?
There will be a sandy area, pampas grass, some large shells, maybe, gulp..a pink flamingo (I know it's a lil over the top, but we like em..just 1) surronding the waterfall..
diyntn is offline   Reply With Quote
Old 11-13-2009, 05:26 PM   #2
I think as I look at this, I would like to know the basics of waterfalls...
What is needed/required?
pump and tubing
something to have water fall off of...
what else?
Is that how it goes? What else is needed....
I'm seeing the block wall thing sit in some sort of basin, tiles laid on the bottom and an underwater blue light shining up thru it all.
How do you keep that sorta setup algae free???
Old 11-14-2009, 06:49 AM   #3
Your idea sounds awesome! Check this out: www.takendodesign.com/cgi-bin/page.cgi?Point_article1
Hope it helps. Good luck & God Bless!
Lali is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
calculating amount of exhaust vents needed bitty071203 HVAC 4 06-09-2009 07:13 PM
how to make waterfall with fake rocks ponch37300 Landscaping & Lawn Care 11 05-22-2009 01:04 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 06:34 PM
