Waterfall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 11:10 PM   #1
Waterfall
how do i build a base for a small waterfall?
topcop565 is offline   Reply With Quote
Old 07-26-2012, 11:13 PM   #2
how do i build a base for a waterfall
Old 07-27-2012, 02:09 AM   #3
Rewards Points: 502
how do I build a wall?
tony.g is offline   Reply With Quote
Old 07-27-2012, 07:01 AM   #4
Rewards Points: 1,294
Dig a hole...put concrete in. If you want more info, you will need to provide morew info on the project you are trying to do
danpik is offline   Reply With Quote
Old 07-27-2012, 07:32 AM   #5
Rewards Points: 502
Is that for building a base for a waterfall,or building a wall?
Old 07-27-2012, 09:23 AM   #6
DIY-er
If you want to have a recirculating system, you need a base that contains the water and won't let it seep through. A PVC liner is typically used. You can buy one as part of a pond building kit or find a manufacturer on google. On top of the liner you could put rocks to make the bottom look natural.
If the waterfall is part of a continually flowing river, you can just line the bottom with rocks so the falling water doesn't erode the soil. Hope this helps.
KevinPh is offline   Reply With Quote
Old 07-27-2012, 04:27 PM   #7
An old Tradesmen
Rewards Points: 6,540
Moved to landscaping forum.
waterfall doug11 Landscaping & Lawn Care 0 09-13-2011 11:25 AM
Waterfall help needed diyntn Landscaping & Lawn Care 2 11-14-2009 07:49 AM
how to make waterfall with fake rocks ponch37300 Landscaping & Lawn Care 11 05-22-2009 02:04 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 07:34 PM
Run submerged waterfall pump without water, what will happen herbolaryo Electrical 2 08-15-2007 07:03 PM
