Water well in my yard and no pump.
In order to show that the well is useful you have to try to pump water out of it, in other words invest in a pump first. You can wire up the pump to a plug and use an extension cord while testing the well.
You can test by letting the pumped water gush out onto the ground but when you decide to install the pump for good, you will need an expansion tank perhaps ten to twnety gallons in size.
Sometimes you won't get enough of a water flow to keep an ordinary lawn sprinkler going.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
